Need bios DINABOOK SATELLITE PRO C40-H-100 PYS36E-007028CE 11092523H
  • Simon16
    • Sep 2017
    • 102
    • España
    Please, need bios for:
    DINABOOK SATELLITE PRO C40-H-100 PYS36E-007028CE S/N: 11092523H
    MB: IP3_IN16_MB_V21_20200831A
    CPU - intel SRGKG
    Bios chips - W25Q128JV
    KBC -IT5570E-CXS
    I attach a copy of the original bin file.
    I also attach file for updating this bios and that I cannot unzip
  • Simon16
    • Sep 2017
    • 102
    • España
    Re: Need bios DINABOOK SATELLITE PRO C40-H-100 PYS36E-007028CE 11092523H
    Does anyone know how I can extract the files from the attached archive?
    To try to compose a bin file.
    Thank you,
    • essaadi
      • May 2016
      • 53
      • MOROCCO
      Satellite pro c40-g-126 pys26e
      I need to clear password please.
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        Re: Satellite pro c40-g-126 pys26e
        Here's your Unlocked file, hope it works fine.
        all donations are welcome,
        • essaadi
          • May 2016
          • 53
          • MOROCCO
          thank you for help, but password not cleared...
          • essaadi
            • May 2016
            • 53
            • MOROCCO
            I manage to unlock it basing on your reply...
            Thank you for your fast reply.
            • jowy
              • Jul 2024
              • 6
              • Spain
              How did you do it to be able to enter the bios with that .bin file? I have no idea, I downloaded the .rar file and there I wasHow did you do it to be able to enter the bios with that .bin file? I have no idea, I downloaded the .rar file and there I was
              • peste
                • 13924
                • ROMANIA
                you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                • jowy
                  • Jul 2024
                  • 6
                  • Spain
                  Is there any other way to open that .bin file? like for example a rufus usb or something like that, or from windows (which I suspect is not) I wouldn't like to remove the spark plug to be able to unsolder anything from the board, I've tried removing the battery and that doesn't work either, I'm lost
                  • jowy
                    • Jul 2024
                    • 6
                    • Spain
                    Hello again, removing the bottom cover I have seen this (red circle) and I would like to know if making a point would work to remove the password, I have seen videos of other Toshiba models that have a kind of ''connectors" (I don't know). I'm referring to the CMOS one) where they tap it and remove the password. I've also seen the manual for this c40-g and it says the following: "Short circuit PCB test point TP30 and TP81 copper spots, press the power button, the machine into The BIOS reset state." Could someone tell me where that is? There is no explanatory manual Thanks in advance
                    • jowy
                      • Jul 2024
                      • 6
                      • Spain
                      Hi, I did everything I found in the videos with the CH341 eeprom programmer and I can't remove the password, is there any particular point to look at? I deleted the eeprom and rewrote it with the file you sent. Is this how it works? Or do I have to overwrite without deleting the eeprom?
