HP Elitebook x360 1030 G3 - clean dump needed
  • szogun
    • Jun 2017
    • 18
    • Poland
    Long story short - BIOS update from Windows Update went sideways
    Notebook is turning on, but it has a "bios update loop". I`ve tried bios crisis/recovery/repair magic tricks (Win+B, Win+V, USB recovery disk etc) nothing helped.
    So, i need clean dump, without passwords to reprogram my eeprom again. Can somebody help me?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12325
    Re: HP Elitebook x360 1030 G3 - clean dump needed
    Post your corrupt bios file here.
    • szogun
      • Jun 2017
      • 18
      • Poland
      Here you go
      • hardware1
        • Sep 2021
        • 2948
        • N/A
        Here you go
        Here's your new file, try it and give me the results.
        all donations are welcome,
        • szogun
          • Jun 2017
          • 18
          • Poland
          Thank you, but it didn't help. Actually quite opposite, because now i have no video signal, batttery LED blinks very fast and Caps Lock LED is on
          • hoaca388
            Badcaps
            • Jan 2022
            • 12325
            HP EliteBook x360 1030 G3 Notebook PC latest bios
            Serial : 5CD029FFDJ
            • szogun
              • Jun 2017
              • 18
              • Poland
              Unfortunately still no luck - Caps Lock blinks 7 times. AFAIK, this means that Sure Start is unable to find valid BIOS Boot Block image.
              • filewalker
                • Dec 2020
                • 16
                HP Elitebook x360 1030 G3 Clean Dump
                I have a HP Elitebook x360 here, that shows a weird behavior. When it starts the fans keep ramping up. The screen works and shows a small cursor on the upper left corner. After one minute or so it starts so I can enter the BIOS.
                When a SSD is attached it simply restarts when it tries to boot. When no SSD is attached it tries to boot PXE.
                I already tried to reset security settings and update the BIOS. My next thought is eighter a clean rewrite of the BIOS or that some electronics are faulty and I have to replace the mainboard.
                Can anybody make a clean image for me? Files are attached.
                Thanks for your help
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12325
                  Re: HP Elitebook x360 1030 G3 Clean Dump
                  • filewalker
                    • Dec 2020
                    • 16
                    Thank you hoaca388,
                    unfortunately I just had a black screen. No fans starting, only the LED on the keyboard lit up.
                    • szogun
                      • Jun 2017
                      • 18
                      • Poland
                      Thank you hoaca388,
                      What is your programming hardware and software?
                      In my case, fault was on Asprogrammer.
                      After writing bin file, delivered by hoaca388 with Neoprogrammer, my notebook started to work and everything is fine.
                      Thank you hoaca388 for your help. I owe you a big cup of coffe or glass of beer.
                      KUDOS
                      • zszahid
                        • Jun 2021
                        • 35
                        • Pakistan
                        hi i need clean me region bios for my x360 1030 g3 , here is my orignal dump with 40 seconds late display
                        • hardware1
                          • Sep 2021
                          • 2948
                          • N/A
                          Here's your Clean file.
                          • zszahid
                            • Jun 2021
                            • 35
                            • Pakistan
                            thanx dear
                            • Tjaytony
                              • Oct 2020
                              • 114
                              • Nigeria
                              I dont know if i am suppose to request for this here. i have hp x360 1030 g3 here stuck at bios update. i attached an image for better description.
                              will really appreciate it if anyone could help fix this
                              • hardware1
                                • Sep 2021
                                • 2948
                                • N/A
                                Your Backup file is messy, try to read it again correctly.
                                Do you remember what was your BIOS Version before update? Also write your Device Serial Number.
                                • Tjaytony
                                  • Oct 2020
                                  • 114
                                  • Nigeria
                                  i felt it was messy also cus of the size. i read it again anyways. its a 32mb bin. after compression i get 333kb file.
                                  here is the backup after reading it again.
                                  the serial number is : 5CD9237B5Q
                                  And its a customer's device, so i dont know the bios version before this error.
                                  • hardware1
                                    • Sep 2021
                                    • 2948
                                    • N/A
                                    The compressed file size for 32MB .bin file should be more than 9MB.
                                    Which Programmer do you use to read the Chip? Do you use a clip or de-solder the Chip?
                                    • Tjaytony
                                      • Oct 2020
                                      • 114
                                      • Nigeria
                                      i disoldered the chip. should i just upload the bin file. or you could just extract the one i sent to you. its a 32mb bin file inside.
                                      i am also surprised that after compressing the bin file i get 333kb zip file. i have read the chip several times and compressed it. its the same zip size i get. i even compressed it to 7zip format. i get 111kb file instead.
                                      and i am using an EZ2019 programmer
                                      • hardware1
                                        • Sep 2021
                                        • 2948
                                        • N/A
                                        I know that your file is 32MB but it shouldn't be less than 1MB after compressing. I don't use EZ2019, maybe someone else can gives you any hints for that Programmer.
                                          HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:27 AM
                                          HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 06:40 AM
                                          09-06-2024, 05:33 AM
                                          HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 11:32 AM
