hp compaq 2230s bios
  • nomad26
    • Feb 2016
    • 18
    • algeria
    please i need bios file for hp compaq 2230s but has password. this is the original bios thank's
  • hoaca388
    Badcaps
    • Jan 2022
    • 12438
    Re: hp compaq 2230s bios
    HP Compaq 2230s Notebook PC.
    Serial number : CNU8500Z7R
    • nomad26
      • Feb 2016
      • 18
      • algeria
      tested not OK please give me another this is the orginal bios dump attached
      • hoaca388
        Badcaps
        • Jan 2022
        • 12438
        Ok, try.
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          If hoaca388 files don't work with your device. did you tried to enter the wrong password 3 times and see what code will appear. 5 digits, 8 digits, 10 char and so on..
          all donations are welcome,
          • nomad26
            • Feb 2016
            • 18
            • algeria
            not code appear i have message = system locked presse the power button to restart the system
            • nomad26
              • Feb 2016
              • 18
              • algeria
              not ok this dump
              • Ali5914
                • Dec 2020
                • 48
                • India
                Try this....
                • nomad26
                  • Feb 2016
                  • 18
                  • algeria
                  not works please parch second dump not fisrt dump (2230.rar ) this is the orginal dump thank"s
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12438
                    The last one.
                    • nomad26
                      • Feb 2016
                      • 18
                      • algeria
                      thank you and I'm sorry for the inconvenience I tried all the dumps the pc does not start it only works with its dump
                      • nomad26
                        • Feb 2016
                        • 18
                        • algeria
                        there is no other method to remove the password
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12438
                          Try last of last one
                          • Ali5914
                            • Dec 2020
                            • 48
                            • India
                            Please try
                            • Radiare
                              • May 2022
                              • Uzbekistan
                              I faced a similar problem, I was helped by replacing the BIOS chip, if it does not help, I will send a dump from my laptop
                              • to5it0
                                by to5it0
                                10-24-2025, 01:35 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
                              • maanee11
                                Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                                by maanee11
                                Hello Everyone,
                                I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                                It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                                In the website, you can only see specs etc.
                                I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                                11-08-2025, 04:08 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                Hi everyone
                                09-06-2025, 05:47 PM
                              • Forest79
                                by Forest79
                                07-23-2023, 07:39 AM
