Dell Precision 5530 - corrupted bios ?
  • TheQuentincc
    • Mar 2017
    • 64
    • France
    I have a Dell Precision 5530 (I7 8750H, Quadro P2000, Thunderbolt 3) which is not booting anymore. When I press the power button it lights up for 5 to 20sec, sometime the keyboard can light up, but nothing on screen. When I remove entirely the memory module it acts the same, there is no orange/white blinking, that makes me thinks it's the bios that's having an issue... Also the previous owner told me it never booted again since a bios update.
    Here is the dump, seems normal to me, works with UEFITool but it's probably somehow corrupted, I also saw 2 other 1MB eeprom on the board that's for thunderbolt I guess (but if it was corrupt, why the laptop would not recognize empty memory slot/make a debug LED code ?)
    Can someone help me please ?
    Thanks you
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Dell Precision 5530 - corrupted bios ?
    Ignore Thunderbolt chips, nothing to do with your issue. I'll see if i can find a dump for this and come back later to help.
    EDIT: Found here on Badcaps forum, apparently this is working clear ME dump. https://www.badcaps.net/forum/showpo...10&postcount=7
    Check Parser section of UEFITool, yours has a lot of errors.
    A working TV? How boring!
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Thanks you
      Here's your new file, try it and give me the results.
      all donations are welcome,
      • TheQuentincc
        • Mar 2017
        • 64
        • France
        Thank you, is it a reliable information to check each time I make a dump ? What do you think about Hardware1 file ? there is still a lot of "error".
        Hi, thanks, I can see there is still a "lot" of error in the Parser section of UEFITool, by curiosity what did you do to my dump ?
        Sorry if I seems a bit rough but it's a bit painful for me this time, I don't have access to hot air station and to dump/flash my chip I'm desoldering the chip then solder many wire on the eeprom each time (I don't have any board adapter right now)...
        I could have used the header on the board but I had issue in the past with my programmer (modded CH341A) doesn't providing enough power to the whole board...
        • TheQuentincc
          • Mar 2017
          • 64
          • France
          So, the power button doesn't even light up, there is no reaction when pressing the power button...
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Haven't checked and it's really not my business, I've got a ton of things going on.
            No idea what they did, but check the link in my post above, that one's got no errors. See if it works. And yes, as far as my experience with it goes, the Parser section is pretty reliable. All I know is no image or no power to CPU, dump BIOS, have errors, fix BIOS and ME, no errors, flash, it works for me 95% of the time.
            I've used a lot of different programmers and also built my own, I still desolder the chips every time. Clips are not reliable for many boards even on a high end programmer like a TL866 II or a RT809H.
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              I had repaired your file using latest bios region from Dell, cleaned ME and replaced your service tag padding from your old to the new file.
              I think i had made something wrong or need to replace something more.
              • TheQuentincc
                • Mar 2017
                • 64
                • France
                Neither of those two files has worked, there is no reaction when the power button is pressed.
                I have an interesting behavior that might not be related to the vbios (I'm gonna flash my original one later to confirm if it's related to your bios or the board), when the PSU and battery is plugged, the LED battery charge indicator doesn't even light up when I press the "battery indicator button", however when I unplug the PSU and let only the battery, these LED does light up for like 100ms when pressing the "battery indicator button" (which is not the original behavior with the original corrupted bios), it's a bit strange, FIY these LED are "connected" to the MEC5105/EC controller, maybe there is something bad with the EC firmware ?
                Also @Th3_uN1Qu3, it seems like the bios you provided is made for the LA-F541P board, which seems very similar to mine (I have LA-G341P with N18P-Q3-A1 Quadro P2000 GPU core, I should have started with that) but I'm unsure of the real difference. Furthermore I don't see an eeprom for the dGPU vbios, so it's probably embedded in the main bios file ? does it contain all the vbios that are "compatible" with the board ? (which should be 1050+1050Ti+P1000+P2000, counting XPS configuration)
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Sometimes it is embedded in main BIOS, yes. Sometimes it is a smaller, standard SO-8 package, rather than the wide one you are used to see with the regular main BIOS chips.
                  • TheQuentincc
                    • Mar 2017
                    • 64
                    • France
                    I think I broke something or the board died by itself, I started a thread in the right section explaining what's going on https://www.badcaps.net/forum/showthread.php?t=112182
                    • DZ-Developer
                      • Nov 2022
                      • 28
                      • Algeria
                      Hello
                      Dell Precision 5530
                      Motherboard: DDP00/DDB00 LA-G341P REV:1.0
                      i need Clean up Password Bios
                      Many thanks in advance
                      see the donate button below, at the bottom of the page, or
                      >>>>> click on this link to donate via PayPal. <<<<<
                      Doctrina est fructus dulcis, radicis amarae
                      • landlord120
                        • May 2018
                        • 7
                        • Egypt
                        I have Dell Precision 5530 with Intel XEON and Quadro P2000.
                        After bios update from windows update i found a yellow triangle on Nvidia display driver and no vbios information in gpuz.
                        I tried to downgrade bios with 1.37 version but nothing fixed and bios itself become read only, after saving changes and restart it doesn't save any changes I made on F2 bios menus.
                        Can anyone help me?
                          • 22170
                          Can anyone help me?
                          Thread merged. Read the rules please, post the service tag --> https://www.badcaps.net/forum/troubl...before-posting
                          • landlord120
                            • May 2018
                            • 7
                            • Egypt
                            Please accept my apology,
                            Service Tag : 929GLQ2​
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12423
                              Try
                              ​https://www.badcaps.net/donate
                              • landlord120
                                • May 2018
                                • 7
                                • Egypt
                                Originally posted by hoaca388
                                Try
                                didn't work, fans just spinning
                                • qayyum786
                                  • Aug 2018
                                  • 1959
                                  • INDIA
                                  Try again
                                  • landlord120
                                    • May 2018
                                    • 7
                                    • Egypt
                                    Originally posted by qayyum786
                                    Try again
                                    the same thing, only fans working
                                    • Barttech Computers
                                      • Dec 2024
                                      • 27
                                      • Usa
                                      Hi guys can you please help with Dell Security Manager
                                      Dell Precision 5530
                                      ST 80MT3Z2
                                      EX 17452568414
                                      board LA-F211
                                      • Christian_E
                                        • Apr 2025
                                        Hello, my Notebook is Protected by Bios Password, can anyone help me Please?
                                        The Service Tag is :356SMV2
                                        Many Thanks and Happy Eastern from Germany:-)
                                        • peste
                                          peste commented
                                          Editing a comment
                                          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                      • mizzed
                                        Bios Request - Dell Precision 5530 2in1 LA-F211P rev 1.0 - updated
                                        by mizzed
                                        Hi, Would anyone have a bios dump for a Dell Precision 5530 2in1 LA-F211P rev 1.0.
                                        Following a failed bios, I had a new bios chip programmed with the the XPS 15 9575 2in1 LA-F211P rev 1.0, which the motherboard has identical model numbers, (having not being able to find a 5530 2in1 bios) however both in bios and os, the Vega graphics, and sound boards are not detected or installable, everything else worked fine. The only difference I can see is that although the motherboards are nearly identical is that they have slightly different CPU/GPU 8705g vs 8706g.
                                        If anyone...
                                        01-05-2023, 06:53 AM
                                      • trix11
                                        Dell Precision T1650 MT Workstation bricked after BIOS update
                                        by trix11
                                        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                        - Dell Precision T1650 mid tower Workstation
                                        - Xeon E3-1225 V2
                                        - 32Gb PC3-12800E RAM
                                        - 4Tb SATA HDD
                                        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                        I see now that others have experienced like issues e.g.:
                                        - https://www.dell.com/community/Prec...
                                        10-24-2022, 10:35 PM
                                        DELL Precision 5530 Mobile workstation 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Precision 5530 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5530 boardview and 5530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                        09-06-2024, 05:30 PM
                                        09-06-2024, 03:30 PM
                                        DELL Precision 5530 Mobile workstation 3000 Specification for Upgrade or Repair
