Dell Precision 5530 - corrupted bios ?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12240
    Originally posted by Christian_E
    Hello, my Notebook is Protected by Bios Password, can anyone help me Please?
    The Service Tag is :356SMV2
    Many Thanks and Happy Eastern from Germany:-)
    Unlocked
    • Christian_E
      • Apr 2025
      It works, many Thanks!
      • ngovanchung
        • Apr 2022
        • 12
        • vietnam
        I lost the original BIOS, this BIOS file works for me, but after a few reboots, it only lights up the keyboard and nothing appears on the screen. Can anyone help me edit it?
        Dell precision 5530 core i7-8h
        tag : 8VD67Y2
        • hoaca388
          Badcaps
          • Jan 2022
          • 12240
          tag : 8VD67Y2
          Precision 5530
          Service Tag: 8VD67Y2​
          • ngovanchung
            • Apr 2022
            • 12
            • vietnam
            Originally posted by hoaca388
            Precision 5530
            after editing it doesn't work
            • sibuskk
              • Aug 2025
              • India
              #26
              my dell precision 5530 is not booting anymore, no display, nothing. Initially there was a 2-1 cpu fail error indication, I tried resetting the BIOS by long pressing the power button for 25 seconds.
              Now there is no display, but keyboard is getting lit as soon as the AC adapter is plugged in, even without pressing power button. The error indication is gone, fan will spin for some time, ramp up and then switches off.
              LCD self test works.
              I'm assuming that the issue is with BIOS (no other obvious faults are detected such as components getting hot, liquid damage...). So, I desoldered the flash-chip and read the bios using a raspberry pi.
              I'm attaching the firmware dump, can someone please check if the BIOS is corrupted or not. ?
              service tag : 5P2M3Z2
              motherboard" DDP00/DDB00 LA-G341P rev 1.0(A00) (dated 2018-05-28)
                • 21597
                Your backup is no good. Compare your compressed file which is 6.0KB to the others in the thread which are 9-11MB .Make another backup.
                • sibuskk
                  • Aug 2025
                  • India
                  #28
                  Sorry
                  Just realised that I took backup of the wrong flash chip, the real BIOS chip was right next to the PCH, but I didn't see that. The backup I shared before is of a winbond flash chip on the other side. The real BIOS is on a gigadevice chip. As soon as I saw a winbond chip I assumed that it was the bios chip. Sorry.
                  attaching the new correct file now.
                  md5sum for the binary file : 3c7c503abe7061c9de1be393e846bd0e
                  thanks you
                  • sibuskk
                    • Aug 2025
                    • India
                    #29
                    After two sleepless nights, I taught myself how to check and rebuild the BIOS, using various tools such as dell_pfs_extract script, uefitools, MEAnalyzer, intel FIT, ImHex (best linux alternative I found for HxD, and I like it more)... was a deep rabbit hole.
                    But now the problem is the new BIOS doesn't contain the service tag.
                    The Service tags were all in BIOS region of the original dump, and I replaced it with the one extracted from dell official bios update exe.
                    What to do ?
                    if I flash this bios, can I expect a prompt to enter the service tag (as if I changed the motherboard?)
                    Just like service tag, windows key will be lost as well, right ? (I don't have a windows key, but just curious on how to restore).
                    can someone help me with this ? especially service tags ?
                    any videos, blogs ... ??
                    I''m also attaching the BIOS file that I built if anyone is willing to help with verifying it..
                    Md5sum of the bin file : c449654a600d4811bd5cdc53f2ca3f62
                    • duong.160694@gmail.com
                      • Nov 2017
                      • 27
                      • viennam
                      #30
                      Dell Precision 5530
                      ST 3HXW6S2
                      LA-G341P
                      STARTUP WITH A WARNING:" (A7) ME FW DOWNGRADE-REQUEST MESPILOCK FAILIED"
                      HELP ME
                      • mizzed
                        Bios Request - Dell Precision 5530 2in1 LA-F211P rev 1.0 - updated
                        by mizzed
                        Hi, Would anyone have a bios dump for a Dell Precision 5530 2in1 LA-F211P rev 1.0.
                        Following a failed bios, I had a new bios chip programmed with the the XPS 15 9575 2in1 LA-F211P rev 1.0, which the motherboard has identical model numbers, (having not being able to find a 5530 2in1 bios) however both in bios and os, the Vega graphics, and sound boards are not detected or installable, everything else worked fine. The only difference I can see is that although the motherboards are nearly identical is that they have slightly different CPU/GPU 8705g vs 8706g.
                        If anyone...
                        01-05-2023, 06:53 AM
                      • trix11
                        Dell Precision T1650 MT Workstation bricked after BIOS update
                        by trix11
                        I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                        - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                        - Dell Precision T1650 mid tower Workstation
                        - Xeon E3-1225 V2
                        - 32Gb PC3-12800E RAM
                        - 4Tb SATA HDD
                        - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                        I see now that others have experienced like issues e.g.:
                        - https://www.dell.com/community/Prec...
                        10-24-2022, 10:35 PM
                        DELL Precision 5530 Mobile workstation 5000 Specification for Upgrade or Repair
                        This specification for the DELL Precision 5530 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5530 boardview and 5530 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                        09-06-2024, 05:30 PM
                        09-06-2024, 03:30 PM
                        DELL Precision 5530 Mobile workstation 3000 Specification for Upgrade or Repair
