Took read of chip with wrong selected MB from programmer. The current BIN i have backed up is 128MB and it needs to fit on a 64mb chip. Is there an application that makes this easy to shink the BIN and keep all data intact? I am familiar with HeXHD. Any help would be appreciated.
Need to shrink a 128 MB BIN to 64mb.Inspiron 3593
Re: Need to shrink a 128 MB BIN to 64mb
The programmer might have read the chip twice,so the same 8MB of data following on, or 8MB of data followed by 8MB of zero`s or FF`s .If you havn`t already written anything to the chip or erased it its ok to read it again ,just choose the chip manually instead of using Auto-detect.Your backup can be edited to the right size with a hex editor. Is your programmer an EZP**** ,CH341A or something else ,and what is the motherboard model numberTook read of chip with wrong selected MB from programmer. The current BIN i have backed up is 128MB and it needs to fit on a 64mb chip. Is there an application that makes this easy to shink the BIN and keep all data intact? I am familiar with HeXHD. Any help would be appreciated.
.Last edited by SMDFlea; 11-01-2022, 04:34 PM. -
SMDFlea,
My sincere apologies for not getting back to you sooner. I was not expecting a reply so fast. Thank you!
Update: The chip was already erased. So the original is lost other than what I have backed up on the 128MB BIN. The programmer I am using is a TL866II Plus. The backup is of the XMC 0H64AH1G chip from a LA-J081P motherboard. I can attach the original backup of the chip here if that helps? Any further assistance is greatly appreciated and I will monitor this post.
Here is the original 128MB BIN.Attached Filesif you find these attachements useful please consider making a small donation to the site
Can you write your device model, and what was your main problem?
As I can see, your 16MB file is duplicated, it has 2 similar 8MB files.
Also you must have another 16MB bios file, because the Vscc Table shows 2 chips (8MB+16MB).----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Sure thing. My buddy attempted to flash his BIOS on his Dell Inspiron 3593. The problem is he didnt have a power adapter connected at the time and his battery went dead in the middle of flash. He backed up the chips but used 128MB selection for the XMC chip. The other BIOS chip is all set. I was able to buy a new chip and flash that chip with the original BIN. Can you think of a way to shrink the BIN i uploaded to fit on a 64MB chip while at the same time keeping the data intact? I am not great with Hex Editors. Only familiar with HxD.Comment
You can open the file with HxD and select block from 0h to 800000h, that will be the half (8MB). If you select from 800000h to the end, it will be the same.Sure thing. My buddy attempted to flash his BIOS on his Dell Inspiron 3593. The problem is he didnt have a power adapter connected at the time and his battery went dead in the middle of flash. He backed up the chips but used 128MB selection for the XMC chip. The other BIOS chip is all set. I was able to buy a new chip and flash that chip with the original BIN. Can you think of a way to shrink the BIN i uploaded to fit on a 64MB chip while at the same time keeping the data intact? I am not great with Hex Editors. Only familiar with HxD.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Need to shrink a 128 MB BIN to 64mb.Inspiron 3593
Like this? Then you just delete the F's? I will flash the chip with the BIN you modified for me and provide an update. Thank you hardware1. Much appreciated!
If you`re starting from 0 No, the length in hex should be 800000 , 0 - 7FFFFF .Why is that ? ,because the counting starts from 0 and not 1
If you were selecting the bottom 8MB of the 16MB it would start at 800000 and end at FFFFFF
.Last edited by SMDFlea; 12-21-2022, 04:51 PM.Comment
Okay i surface mount soldered the chip back, reassembled and now i have no power, no lights, no fan. Before the change, I had power and could boot to BIOS and Windows. Now nothing. The reason for flashing the XMC chip is to correct the Serial number. Could the deletion and downsizing messed with the prompt to boot? I have 19 volts coming in from the charger to the dc in. And 3.3 v going to the chip replaced. But after taking readings on the XMC chip, i switch to the Winbond and get 0v. Has to be the chips not talking to one another. Here is a pic of the solder work. Anything else we can try?Attached Filesif you find these attachements useful please consider making a small donation to the site
I think the best way is to upload your both chips files (the first Backup anyway), write your device service tag and someone will try to help you.Okay i surface mount soldered the chip back, reassembled and now i have no power, no lights, no fan. Before the change, I had power and could boot to BIOS and Windows. Now nothing. The reason for flashing the XMC chip is to correct the Serial number. Could the deletion and downsizing messed with the prompt to boot? I have 19 volts coming in from the charger to the dc in. And 3.3 v going to the chip replaced. But after taking readings on the XMC chip, i switch to the Winbond and get 0v. Has to be the chips not talking to one another. Here is a pic of the solder work. Anything else we can try?
Also write what was written on the top of your old chips and the new chips too.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hardware1,
Okay sounds good. I will remove my Windows product key from the padding of the BIN for the first chip and replace with dummy product code prior to uploading. I will also compile and list the details of the chips. Will be uploading soon today. Thanks!Comment
Hardware1,
Here are both original backups of the chips. I did notice that my buddy not only selected the wrong size to do the XMC chip backup. He also selected the wrong chip in the programmer. Both chips were backed up with the Windbond chip selection. the XMC chip should have been backed up by the programmer using "XM25Qh64A" but W25Q128JV was used in place. The Winbond chip is W25Q128JV. I will upload a follow up pic of both chips with their full descriptions. Thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
Here's your new bios files, try them.Hardware1,
Hardware1,
Do I have to remove both chips from the board again and re-flash both? The Winbond chip was working prior to the flash of the XMC. Can you elaborate a bit on your investigation and theory? Just trying to get a better grasp on this editing. Thank you.Comment
Our goal is to make the device works fine, so yes the best way is to desolder the both chips and program them with the files which I uploaded.
Your bios has fixed using the Bios Region that provided by Dell, then I cleaned the ME Region.
If the files are compatible (and there is no other issues) the device will work, if not so you have nothing to lose because you already have the backup.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Okay sounds good. I will update the Windows Product key on the modified BIN you provided in the padding for the Winbond chip prior to re-flashing. Anything else I am missing for steps? Thank you.
Hardware1,
I flashed, mounted and reassembled. Machine boots to BIOS recovery screen but I am not able to recover the BIOS (using currently flashed BIOS). The other options are Rollback to previous BIOS or Load BIOS defaults. Should I just pick Load BIOS defaults?Attached Filesif you find these attachements useful please consider making a small donation to the site
I'm really don't know, but you can upload a picture and maybe someone can help you.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by SMDFleaAdding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
and once you do find them there`s a few crucial steps missing.
Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
After adding the chip save the xml file and copy it to the root directory of the...-
Channel: BIOS Requests ONLY!
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... -
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by TroystainHello, anyone here have updated ezp2023+ chip database in .dat file format.
I need to add w25q256jveq chip but I do not know what data should I type.
I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....11-25-2024, 12:53 AM - Loading...
