T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
Re: T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
check again wires, maybe you reversed TDI with TDO. And choose MEC1633_256k for RT809H----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
I tried all the options in the programmer's list, MEC1633#ISP, MEC1633#256K etc.Comment
https://www.badcaps.net/forum/showpo...&postcount=234----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Hello. I have a problem with T14s and EC Mec1633-BA0 reading. I'm using SVOD4, after changing the place of the resistor and connecting the JTAG
MEC IDCODE: B1240020
Device ID: 0
Device Revision: 0
Device Status: 0
Flash Status: 0000000000
Boot Block in not protected mode
Flash Configuration: 0000000000
Start reading: 11.08.2023 08:00:39
End reading: 11.08.2023 08:00:40
CRC calculated 1D0F
CRC stored 0000
Read OK
But the read dump is empty, it seems to me that I connected the JTAG correctly, with the same connection in x390 it reads EC correctly. Does anyone have an idea?Comment
I'm facing the same problem as rumpumpel on a T14 Gen1. I successfully dumped the MEC with MEC1633#ISP setting. However, after reflashing there is no fan, no LED, nothing. After having a look at the dump it seems like the last bytes got cut off and I should've dumped it using the 256K option. But as I don't have a second device, now I don't have access to the full image anymore.
Would someone mind sharing their MEC1633 dump with me or has any idea where I can find one?Comment
Okay I fixed it by flashing the MEC1633 image of a T490 which is also 256kb. I found it in this post: https://www.badcaps.net/forum/showpo...&postcount=170
Now everything works fine and the supervisor password is indeed gone.Comment
Nice explanation and tutorial by coolshrimp regarding these Lenovo laptops. I have some ambiguities on how do I do this whole procedure with just Keyboard connector cable and with the least possible soldering (without JTAG). As I have the full set of RT809H when I bought it, I think I may not miss a single item because when I bought it I acquired the biggest set with over than 50 parts.
I saw RethoricalCheese used just the Keyboard connector to do the job, but I am not understanding the concept of Pull Up - Pull Down resistor, 10 K, and where do I solder that?
P.S.
Just noticed on the picture attached the description: Resistor Below goes here or place a 10K resistor. Move resistor below to the above position to enable R/W
Will be trying as coolshrimp described
In my case I Have Thinkpad T14 Gen1 AMD version
thanks in advance for such a great and helpful forumLast edited by ordinateur; 09-30-2023, 08:38 PM.Comment
P.S.
thanks in advance for such a great and helpful forum----------------------------------------------------------------------------------------------------------------------------------------------------------------------
what should be the size of the file after reading, 192 KB or 256 KB? I read 256KB correctly. After deleting the file, it reads 256 KB, I checked the MEC and it is empty and the laptop shows no signs of life. After 5 minutes, I program it again, move the resistor and the laptop starts up, but the password still remains.Comment
I always choose MEC1336_256k to read EC with RT809H and extract EC file from bios update to write it back and worked all times. Also read
https://www.badcaps.net/forum/showth...light=MEC+16xx
and you'll find useful infos.Last edited by volinakis; 10-21-2023, 12:08 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
When i try to identify, i am getting this.
Any advice?
RT809F
Chip ID: 0x00FF0406, the device is not found in the corresponding partnumber, you can click "OK", and then manually add this partnumber with their ID, or copy this message content and chip partnumber, and feedback to the technical support forum: WWW.IFIX.NET.CN o
OK Cancel
Thanks for the work and sharing. If I read it correctly, we can add another 10k resistor to enable JTAG? Thought it’s easier to add and remove than to move the small resistor around. Thank you.Comment
Thanks for the tutorial. I have successfully removed the password. However, I cannot seem to modify the settings such as setting a new SVP password. It shows error “write protected”. Anyone has similar issues? Thanks.Comment
Reflashing BIOS obtained from Lenovo website resolved the issue. And the board serial number (B0) can be found from a sticker on the motherboard. It is much longer than the 11 character long serial number found from BIOS information screen but that’s what the Lenovo maintenance utility takes.Comment
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by farouk_1994Hello i need T14s NM-C891 i/o MEC1663 bin file and bios thank you.
Channel: BIOS Requests ONLY!
This specification for the Lenovo ThinkPad T14s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T14s boardview and T14s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...09-07-2024, 07:20 AM
- Loading...
