Dell xps 15 9530 with locked BIOS
  • estmeister
    • Apr 2022
    Hi can you help with XPS 15 9530 locked
    BIOS my Service Tag is F8CX062
    Many Thanks
  • zhukk
    • Oct 2023
    • sweden
    Re: Dell xps 15 9530 with locked BIOS
    Hi. I also have a problem with the BIOS administrator password. I tried to fix it but to no avail. Maybe someone has experience to fix it. Any help would be appreciated!
    Model XPS 9530 (2013)
    Service tag: GY2LYY1
    Express service code: 36888751657
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • TripTop
      Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
      by TripTop
      Hi
      i have dell latitude E7270 with following symptoms:
      - takes long time to restart.
      - sometimes powers on and then off
      - sometimes while working it just dies,
      From googling online bios clean could possible resolve this?
      i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
      As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
      I reinstall...
      09-09-2024, 02:05 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
