Dell Latitude 5430, LA-L591P Computrace setting unlock
  • hoaca388
    Badcaps
    • Jan 2022
    • 11379
    • Viet Nam
    #341
    Originally posted by marc_ytos
    Greetings, can you help me unlock my bios? My computer is a Dell Latitude 5430 with service tag H2NMSQ3 and motherboard la-l591p. Thank you very much in advance and a hug.
    VVV
    • marc_ytos
      • Apr 2020
      • 141
      • cdmx
      #342
      Originally posted by hoaca388
      VVV
      Thank you very much the help now works thanks
      • santoslao
        • Apr 2017
        • 94
        • BZ
        #343
        Please help me rebuild bios for Latitude 5430
        The equipment is no longer turning on after an attempt to remove the bios password, I believe the file was corrupt because it doesn't turn on even with the original dump! It just turns on the power key led and turns off after a few seconds.
        MB: LA-L591P
        ST: DKCL6Z3
        Attached : bios (16Mb+32Mb)
        Attached : Bios Region and ME FW extracted from bios.
        Thank you!​
        • kalilinux25
          • Mar 2018
          • 2069
          • ZAMBOANGA SIBUGAY
          #344
          MB: LA-L591P
          ST: DKCL6Z3
          Thank you!​
          is the board labeled as HDB42 LA-L591P REV 1.0(A00) 2022-01-13 ???
          • santoslao
            • Apr 2017
            • 94
            • BZ
            #345
            Exactly!
            • dellfox
              • May 2024
              • 6
              • Belgium
              #346
              I've noticed few days ago that my 5430 has Intel ME disabled from factory as a yellow sticker says (3 ME disabled, with a QR code that I masked). This sticker is on the inner face of the bottom case of the laptop.
              So, for people who are interested to have ME disabled (those having same model as mine) or for a technical learning purpose, I attached the dump file of the UC6 chip of my laptop.
              Here are the specs of my laptop, please don't flash the file if you don't know what you are doing, I'm not responsible if you make a mistake :
              Motherboard: HDB42 LA-L591P Rev:1.0(A00)
              i5 1245U (so 12th gen) with touchscreen
              The main bios chip (UC2) : Winbond W25Q256JVEN
              The second bios chip with ME disabled and Dell Safebios​ (still active on my laptop) marked as UC6 on the motherboard is a Winbond 25R128JVSN.
              Best regards and thanks again to Volinakis to have submitted the good bin file to reinitialize my BIOS.
              • kalilinux25
                • Mar 2018
                • 2069
                • ZAMBOANGA SIBUGAY
                #347
                thanks for the contribution we need more people like you thanks
                • santoslao
                  • Apr 2017
                  • 94
                  • BZ
                  #348
                  MB: LA-L591P
                  ST: DKCL6Z3
                  Thank you!​
                  I still need this if anyone can help I would really appreciate it.
                  • kalilinux25
                    • Mar 2018
                    • 2069
                    • ZAMBOANGA SIBUGAY
                    #349
                    try this one
                    • santoslao
                      • Apr 2017
                      • 94
                      • BZ
                      #350
                      try this one
                      It doesn't work, I had already tried to insert another file into the machine, this file the machine only lights up red when the power button is pressed. This file contains a version 1.7.0 of the bios the bios file that I posted is in a version 1.13.1 and is corrupted as I mentioned, I
                      • santoslao
                        • Apr 2017
                        • 94
                        • BZ
                        #351
                        If someone could at least explain to me how I can rebuild it myself, I would be very grateful too. The machine has an ME with a version above the FIT that was used to build it. And when trying to open the file in mFIT it gives errors in both versions.
                        • santoslao
                          • Apr 2017
                          • 94
                          • BZ
                          #352
                          I would like to inform you that with a lot of persistence I managed to rebuild the machine's bios and now it is working again.
                          • F6 Solutions
                            • Jul 2024
                            • 9
                            • Cameroon
                            #353
                            Hello
                            Please need help to unlock bios Dell latitude 5430
                            i7 1265U 12th gen
                            UC2 Winbond W25Q256JVEN
                            UC6 Winbond 25R128JVSN.
                            Service Tag 5Z1SDK3-0001
                            Thanks​
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11379
                              • Viet Nam
                              #354
                              Originally posted by F6 Solutions
                              Hello
                              i7 1265U 12th gen
                              Thanks​
                              Post Winbond W25Q256JVEN chip.
                              • F6 Solutions
                                • Jul 2024
                                • 9
                                • Cameroon
                                #355
                                Ok
                                When I try to read chip on board having error
                                • santoslao
                                  • Apr 2017
                                  • 94
                                  • BZ
                                  #356
                                  Ok
                                  You need to remove the chip from the board, this equipment does not support reading with a soldered chip.
                                  • Dan20701
                                    • Sep 2020
                                    • 192
                                    • United Kingdom
                                    #357
                                    Hello all, Can someone please remove the password for me, I don't have much luck when trying editing Dell bios files.
                                    Dell Latitude 5430
                                    Service Tag, F4MWST3
                                    Thanks so much.​
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11379
                                      • Viet Nam
                                      #358
                                      Dell Latitude 5430
                                      Thanks so much.​
                                      Password removed.
                                      • Dan20701
                                        • Sep 2020
                                        • 192
                                        • United Kingdom
                                        #359
                                        Thanks so much mate, much apricated. I will give an update when I get back to this one.
                                        • Dan20701
                                          • Sep 2020
                                          • 192
                                          • United Kingdom
                                          #360
                                          100% perfected mate, Thanks again.
                                          • kaput
                                            Lenovo Thinkcentre M720q, disable activated Computrace
                                            by kaput
                                            Not a BIOS request per se, but closely related. Please bear with me
                                            A while ago I found an old Lenovo Thinkcentre M720q in pieces in the electronics scrap bin at work. There was only some minor damage to the case, so collected everything and brought it home to let it dry and see if it still worked. It did
                                            Unfortunately Computrace has been activated on it. Since I'm using it as an emulation console with Lakka now, it's no big deal, but would be nice to get rid of the annoying message popping up when entering the UEFI setup, and also learn something along the way....
                                            06-28-2024, 09:36 AM
                                            HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation E5430 Specification for Upgrade or Repair
                                            This specification for the HP xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw6600 Intel Xeon Quad Core 5430 2.66GHz 2GB/250GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                            09-12-2024, 03:36 PM
                                            DELL Latitude 5430 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5430 boardview and 5430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5430...
                                            09-07-2024, 06:31 AM
                                          • Syseng
                                            Lenovo P14s Gen 5 SVP unlock
                                            by Syseng
                                            This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                            The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                            06-22-2025, 07:44 AM
