Need bios for BA41-01935A NY XIDAN-14 Rev 1.1
  • obbiiwan
    • Oct 2022
    • 12
    • Chile
    Hi, i have a broken CH341 and i want to know if is posible to flash bin bios file from Dos (USB Stick) with phlash16.exe if that's posible, pls send me bin file with the procedure.
    Any help is appreciated.
    Samsung laptop: NP500P4C-T02CL
  • peste
    • 13451
    • ROMANIA
    Re: Need bios for BA41-01935A NY XIDAN-14 Rev 1.1
    it's not possible... you need a programmer..
    • obbiiwan
      • Oct 2022
      • 12
      • Chile
      Any alternative to CH341? a buy that one but it's a fake one, my bios (mxic mx25l6406e) dont turn on CH341 maybe for 5.v to 3.3v problem.
      I tried to fix pins to get 3.3v without luck.
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
      • maanee11
        Help to get Lenovo BIOS bin file for Thinkpad T560
        by maanee11
        Hello Everyone,
        I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
        https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
        In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
        05-15-2022, 11:59 AM
      • Loli Popu
        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
        by Loli Popu
        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
        12-13-2024, 08:29 AM
