Hp elitebook 830 G7
  • elaid
    • Mar 2021
    • 20
    • algeria
    Hp elitebook 830 G7
    Hello badcaps members
    i need help to remove bios password
    here is bios dump
    thanks i'm waiting for your answers
  • hoaca388
    Badcaps
    • Jan 2022
    • 12118
    Re: Hp elitebook 830 G7
    Post EC file. It's in another similar chip, probably on the other side of the motherboard.
    • elaid
      • Mar 2021
      • 20
      • algeria
      here is...
      • hoaca388
        Badcaps
        • Jan 2022
        • 12118
        Originally posted by elaid
        here is...
        What chip are you reading? Your file must be 16MB or 32MB so the chip will have the code (this is just an example with the Winbond chip) 25Q128FV... or 25Q256FV...
        • elaid
          • Mar 2021
          • 20
          • algeria
          The first dump is 32 Mb
          • hoaca388
            Badcaps
            • Jan 2022
            • 12118
            Find the second chip.
            • elaid
              • Mar 2021
              • 20
              • algeria
              i found this.
              • Mazorca
                • Jan 2017
                • 463
                Read again, it is empty.
                • elaid
                  • Mar 2021
                  • 20
                  • algeria
                  this time im sure its not empty
                  hope this one is good
                  • Mazorca
                    • Jan 2017
                    • 463
                    Did you try RCUnlocker? Says it can unlock when I dropped it.
                    • elaid
                      • Mar 2021
                      • 20
                      • algeria
                      Thanks it work ..
                      • Wutru
                        HP Elitebook 820 G4 BIOS repair assistance required
                        by Wutru
                        Hi guys,
                        If someone would be able to provide some expertise, I'd be very grateful.
                        BIOS Corruption - Cause
                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                        09-06-2025, 10:32 AM
                      • tlindi
                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                        by tlindi
                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                        Ack
                        Ack
                        01-30-2025, 04:26 AM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • Guest
                        Elitebook 850 G5 BIOS bricked
                        by Guest
                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                        I assume the BIOS update failed, so I searched for the BIOS chip.
                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                        Can the corrupted...
                        03-24-2025, 01:21 AM
                      • AlexRaspberry
                        HP Elitebook X360 1030 G3 remove password BIOS.
                        by AlexRaspberry
                        Password removal option for those who do not have a method through HPUnlocker.
                        This option saves all information in the BIOS (serial number, Windows key, etc.) and also excludes the appearance of BIOS notifications at startup (hp endpoint security controller problem).
                        1. Read BIOS (32MB) and EC (16MB) firmware.
                        Be sure to make backups.
                        2. EC:
                        2.1) Copy the area from the original and paste into a clean "EC (16MB) Clean".
                        Region start - 0, length - DA3000
                        2.2) Find in "EC (16MB) Clean" and...
                        09-13-2021, 12:38 PM
