Originally posted by lapfix
View Post
Dell latitude 7410 8fc8 bios password
Re: Dell latitude 7410 bios password
Originally posted by Obiknobi View PostHi guys (and possibly gals),noob here.
I have this 32MB bin file from a Dell 7410 XMC and need help to remove the Bios Setup Admin Password.
I have already tried modifying the dump with the method that @volinakis suggested but the Password check remains. (Changed 1 Byte at 3 offsets to 00)
Did this Fail because i have another Firmware Version (1.17.0) instead of 1.4.1 which i used as example ?
Any hints or an unlocked dump would be much appreciated.
Thank You!Attached Files
Originally posted by ledro View Posthello,
please help unlock.Attached Files
hello,
Originally posted by omaryou View Postbro you need to read the dump from bios chipAttached Files
Hi
i need code unlock bios
system number : CRRP273-8FC8
Dell latitude 7410 BIOS
HELLO
I HAVE Dell latitude 7410 WITHE CHIP QH256BXIQ I DONT HAVE THIS MODEL CHIP ON MY PROGRAMMESO I CHOSE ENQH256 VDFN8 6X8 AND READ THE DUMP FOR UNLOCK
IS THIS WILL WORK PLS NEED TO UNLOCK THIS DUMP AND CHECK BEFORE ERASE
HNDV593-8FC8Attached Files
Looking for the same here!
Apreciate your help guys!Attached Files
Yes, that's what I noticed when I compared the original and edited file in the hex editor.
But I see that each model has it in a different place.
When I look at different files from the same model, it is in the same place.
So it's enough if I download the original and modified file for the same model, find the difference and modify it in my file and it will work.
Originally posted by bushmann View PostThank you very much.
All works fine.
Can you tell me what software you used to unlock it.
If there is any software.
Originally posted by bushmann View PostUps my mistake.
New correct file is uploaded .Attached Files
Hi .
Please can you help me with unlock this BIOS admin password
ThxAttached FilesLast edited by bushmann; 11-20-2022, 08:13 AM.
