Lenovo Thinkpad E15 gen2 GE4B0/GE5B0 NM-D011
  • Faxe5
    • Nov 2023
    • 4
    • Deutschland
    #101
    unfortunatly I tried to Restore the Bios without an Verified Backup. I get 3 diffrent Bin files before flshing 25R256JVEN Chip.
    Can you help to restore Bios ?
    Laptop doesn't do anything only Power LED is on and Laptop restart every 5 seconds.
    No Clip used, with one of the bin files Backlight comes up before reboot
    Lenovo E15 20-TD - NM-D011
    S/N:PF38DQE2
    Greetings
    • dasa35
      • Nov 2024
      • 4
      • nl
      #102
      Hey friends,
      i also need a fresh bios iso for my E15.
      Serial: PF-2L7B02
      Type: 20TE-S02100
      Bios: 25Q80DVSIG
      Thanx alot!
      • shiyab
        • Sep 2023
        • 1592
        • india
        #103
        Originally posted by dasa35
        Hey friends,
        Serial: PF-2L7B02
        Type: 20TE-S02100
        Bios: 25Q80DVSIG
        Thanx alot!
        need backup bios
        • dasa35
          • Nov 2024
          • 4
          • nl
          #104
          Originally posted by shiyab
          need backup bios
          I attached it to ny posting yesterday, was it wrong?
          BTW: Problem is an unknown supervisorPW on an used-buy laptop. I tried with lenovo_autopatcher, but it didnt worked....
          • hoaca388
            Badcaps
            • Jan 2022
            • 12243
            #105
            You chose the wrong bios chip, 25Q80DVSIG is not a bios chip.
            • dasa35
              • Nov 2024
              • 4
              • nl
              #106
              You are right. Excuse my stupidity, I'm completely new to the subject.
              I think I have found the right chip (winbond 25R256JVEQ).
              I connected my ch341-programmer same way like the other chip and tried to detect the chip via neoprogrammer. Unfortunately I only get the message: “IC not responding”.
              So unfortunately I am not able to read the BIOS from the chip.
              Am I doing something wrong?
              Greetings​
              • peste
                • Dec 2016
                • 13350
                • ROMANIA
                #107
                Greetings​
                don't use the clip, remove the bios chip from the case before writing or reading..if you don't have something to solder the wires between the programmer and the chip..
                https://www.youtube.com/watch?v=DWWigscuQDY
                • dasa35
                  • Nov 2024
                  • 4
                  • nl
                  #108
                  Thank you for your answer.
                  Is there no other way than to desolder the chip? Unfortunately I don't have the necessary equipment like the hot air soldering iron and the knowledge to do this.
                    • 21620
                    A WSON8 pogo adapter but they are just as unreliable as the SOP8 clips.
                    • kare
                      • Feb 2023
                      • 13
                      • türkiye
                      #110
                      Hello ,
                      Can you help me? It starts, there is no image, it gives a warning sound, I have backed up the bios,
                      sn:pf-2LDTXF
                      TYPE:20TE-S0VG00
                      PN:SL11B03796
                      BİOS:25R256JVEQ
                      MAINBOARD:GE4B0/GE5B0 NM-D011 REV1.0
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12243
                        #111
                        Originally posted by kare
                        Hello ,
                        sn:pf-2LDTXF
                        TYPE:20TE-S0VG00
                        PN:SL11B03796
                        BİOS:25R256JVEQ
                        E15 Gen 2 Laptop (ThinkPad) - Type 20TE
                        • kare
                          • Feb 2023
                          • 13
                          • türkiye
                          #112
                          it worked thank you
                          • niherasebe88
                            • Mar 2022
                            • 5
                            • rossia
                            #113
                            Lenovo Thinkpad E14 gen2
                            Board GE4B0/GE5B0 NM-D011 rev 1.0
                            SN PF2HRFX9
                            maybe someone can help me.
                            After numerous attempts to program with different versions of T8227E-256 and 25R256JVEQ, I got a stable result, the laptop turns on, the processor heats up, the cooler turns on, but there is no image
                            I am 100% sure that my problem is in the wrong BIOS
                            Perhaps the 256 KB dump is also faulty
                            My old BIOS is 256 Kb and 32768 KB
                          • telromelectro
                            • Dec 2024
                            • România
                            #114
                            hello, please help me with this problem
                            black screen, only lights on power button and charging.
                            i attached the orig file from mainboard bios- gigadevice 25r256dyig
                            serial no PF-2HBLKM
                            type no 20TD-001CRI
                            lenovo thinkpad e15, intel i5
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12243
                              #115
                              serial no PF-2HBLKM
                              type no 20TD-001CRI
                              E15 Gen 2 Laptop (ThinkPad) - Type 20TD
                              • caretech
                                • Sep 2015
                                • 9
                                • istanbul
                                #116
                                It asks for a password when entering the bios screen.
                                • peste
                                  • Dec 2016
                                  • 13350
                                  • ROMANIA
                                  #117
                                  post S/N, full name and model, motherboard model,TYPE,etc.
                                  post the original contents of the bios chip..
                                  • caretech
                                    • Sep 2015
                                    • 9
                                    • istanbul
                                    #118
                                    SN:PF33X37L
                                    TYPE:20TD-0048TX
                                    PN:SL11B03796
                                    BİOS:25R256DYIG
                                    ANAKART:GE4B0/GE5B0 NM-D011 REV1.0
                                    There is a melodic voice, I would be glad if you could help me
                                  • asalex
                                    • May 2017
                                    • 9
                                    • Russia
                                    #119
                                    На этом BIOS ноутбук запускается, но MAC-адрес отсутствует, а в BIOS пустая версия управления.
                                    Lenovo ThinkPad e15 Gen2
                                    S/N: PF-3JX70W
                                    Метка платы: GE4B0/GE5B0 NM-D011 Rev 1.0
                                    Тип #: 20TD-00GSRT
                                    Свежая версия BIOS, пожалуйста.
                                    Спасибо
                                    On this BIOS the laptop boots, but the MAC address is missing and the BIOS has an empty control version.
                                    S/N: PF-3JX70W
                                    Board Label: GE4B0/GE5B0 NM-D011 Rev 1.0
                                    Type #: 20TD-00GSRT
                                    New BIOS version, please.
                                    Thanks​
                                    in English please...
                                    • asalex
                                      • May 2017
                                      • 9
                                      • Russia
                                      #120
                                      S/N: PF-3JX70W
                                      Тип #: 20TD-00GSRT
                                      Спасибо
                                      S/N: PF-3JX70W
                                      Type #: 20TD-00GSRT
                                      This is the original BIOS and the machine boots up with it, but there is no MAC address and ME version. When trying to update from USB, it reboots without updating.​
