Lenovo Thinkpad E15 gen2 GE4B0/GE5B0 NM-D011
  • vladfxnet
    • Jul 2022
    • 5
    • Ukrain
    #61
    Originally posted by aminealae
    Re: Lenovo Thinkpad E15
    same problem but i hear whistle on 24256E
    Hello, have you solved the problem with the chip whistling? Perhaps we have the same problems with the board. My board starts blinking 3 times as usual and then gives continuous long light signals. The fan does not spin and the keyboard backlight does not turn on. If you solved this problem, tell me how?
    • Markus1741
      • Sep 2020
      • 873
      • N/A
      #62
      You are also welcome to watch this YouTube video, I just saw it today.
      In the Lenovo ThinkPad E14 E15 Gen 2 model, there seems to be a serious processing error in which the Mosfets initially detach from the circuit board due to heat.
      Maybe that will help.
      https://www.youtube.com/watch?v=FQM0cDefHi4
      • alihomee
        • Dec 2012
        • 1580
        • malaysia
        #63
        model is:lenovo E14
        serial is:PF-33A1QT
        tyep is:20TA-00DRMY
        when turns on it gives display with too loud beep and keep on restarting after cmos error...i attached orignal file
        • jomerfx28
          • May 2020
          • 31
          • n/a
          #64
          Lenovo ThinkPad e15 Gen2
          S/N: PF-33JCSV
          Board Label: GE4B0/G35B0 NM-D011 Rev 1.0
          Type #: 20TD-00B7US
          Fresh Bios Please. Thanks
          • hoaca388
            Badcaps
            • Jan 2022
            • 12123
            #65
            Originally posted by alihomee
            model is:lenovo E14
            serial is:PF-33A1QT
            tyep is:20TA-00DRMY
            E14 Gen 2 Laptop (ThinkPad) - Type 20TA
            • struart
              • Aug 2022
              • 39
              • Poland
              #66
              Hello
              I have Lenovo E15 Gen 2 NM-D011 Rev 1.0.
              Laptop starts, power led is on, nothing on screen and restart after 5-10 seconds.
              Laptop data:
              Motherboard NM-D011 Rev 1.0
              Serial number: PF-3PFE3P
              Type Number: 20TD-00GNPB
              P/N: SL11B03796
              Heres dump from Winbound 25R256JVEQ chip dumped via T48 programmer.
              Strange thing is that i cannot verify that chip with dump i made it always shows differencies no matter what programmer i use ch341/ez2013/t48. Chip in adapter no clip used.
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                #67
                Originally posted by struart
                Hello
                Laptop data:
                P/N: SL11B03796
                please try
                • mauradin
                  • Aug 2024
                  Hey all,
                  My E15 Gen 2 stopped charging, and I attempted to troubleshoot. I installed the recommended bios, but it did not resolve the charging issue. I stupidly disabled the built-in-battery as per someone's instructions - however, this bricked my laptop because the AC power won't take, and now the battery is disabled. I attempted a CMOS reset, but I could not get the BIOS to reset to unselect the 'Disable Built-in Battery' option. So I am trying to reprogram my BIOS now.
                  On top of that I also wiped the wrong chip... Can someone get me an export of the data for the: 25Q80DVSIG chip?
                  Additionally, for this laptop, since the BIOS is stored in 25R256JVEN, I don't see a way to desolder this chip, but I do see these contacts. Do I have to temporarily solder wires here to make this work? I'm unsure how to connect to this chip.
                  My laptop:
                  Serial: MJ-0G4908
                  Type: 20TD-S00800
                  Click image for larger version  Name:	Screenshot 2024-08-12 003810.png Views:	0 Size:	713.9 KB ID:	3327399
                  • peste
                    • Dec 2016
                    • 13199
                    • ROMANIA
                    #69
                    I think so...follow the routes in the picture from post #2....
                    • struart
                      • Aug 2022
                      • 39
                      • Poland
                      #70
                      Originally posted by kalilinux25
                      please try
                      On this BIOS laptop starts but theres no MAC address and Managment Version is blank in BIOS and dont detect NVME DISK.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        #71
                        Originally posted by mauradin
                        Hey all,
                        What is the Motherboard Model?
                        • mauradin
                          • Aug 2024
                          Hey it is the
                          GE4B0/GE5B0
                          NM-D01
                          My biggest question right now, is do I have to solder wires onto the contacts by the 'JBIOS' area, and then get those onto my ch341a?
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            #73
                            Hey it is the
                            GE4B0/GE5B0
                            NM-D01
                            Yes you can try I already confirm the connection they are connected to U2 line, but try if the Programmer can detect it , please remove the batery or any that can power the board to avaoid further damage
                            • struart
                              • Aug 2022
                              • 39
                              • Poland
                              #74
                              kalilinux25 Hi
                              Any idea about theres no MAC address and Managment Version is blank in BIOS and dont detect NVME DISK on your BIOS bump?
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                #75
                                kalilinux25 Hi
                                ill try to rebuild it again wait
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  #76
                                  kalilinux25 Hi
                                  • struart
                                    • Aug 2022
                                    • 39
                                    • Poland
                                    #77
                                    kalilinux25
                                    You are GOD!
                                    Laptop is back to live with all data, mac and disc i only copied windows key to proper location and all good.
                                    Thank you very much.
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      #78
                                      kalilinux25
                                      You are GOD!
                                      Great to hear it.
                                      • jomerfx28
                                        • May 2020
                                        • 31
                                        • n/a
                                        #79
                                        S/N: PF-33JCSV
                                        Type #: 20TD-00B7US
                                        Fresh Bios Please. Thanks​
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12123
                                          #80
                                          S/N: PF-33JCSV
                                          Type #: 20TD-00B7US
                                          E15 Gen 2 Laptop (ThinkPad) - Type 20TD
