LENOVO LEGION 5 15ITH6 bios dump
  • dahnking
    • Apr 2018
    • 258
    • kenya
    S/N PF398F5C
    looking for working BIOS
    attached is the original backup
  • peste
    • Dec 2016
    • 12887
    • ROMANIA
    Re: LENOVO LEGION 5 15ITH6 bios dump
    S/N PF398F5C
    bios extracted from Lenovo site update
    DMI D2000 - D422F
    • dahnking
      • Apr 2018
      • 258
      • kenya
      DMI D2000 - D422F
      Thank you sir
      working properly
      • MartinBRM
        • Jan 2023
        • 7
        • Brazil
        LENOVO LEGION 5 15ITH6H
        S/N PF37HA9B
        Bios bricked, looking for a new bios.
        Bricked bios dump attached.
        Looks like it is a 8mb file.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11815
          S/N PF37HA9B
          Your laptop has two bios chips, 8MB+16MB, post both.
          • MartinBRM
            • Jan 2023
            • 7
            • Brazil
            Dump bios twice, both have this 2mb file size...
            • MartinBRM
              • Jan 2023
              • 7
              • Brazil
              Just to clarify, I've dumped the bios using arduino and flashrom, while the 8mb bios dumped a 8mb file, the 16mb one dumped this 2mb file (tested twice on the 16mb one). Maybe i should use another SPI? Is it possible to get thr new bios with just the serial number? Thx.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11815
                The entire bios file for this model can be obtained but it does not have a DMI . Are you sure you have selected the correct 16MB chip?
                • MartinBRM
                  • Jan 2023
                  • 7
                  • Brazil
                  I ve selected the wrong one. Attatched is the write dump. I tried writing your files in the the right chip, but laptop is still bricked, maybe with the right dump it is possible to make the bios files?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11815
                    The file I posted is the virgin file from lenovo, it doesn't work for you means you don't have bios error.
                    • MartinBRM
                      • Jan 2023
                      • 7
                      • Brazil
                      ok. Just to check out if I am doing things right.
                      I`ve set flashrom to write both bios on the write chips, your 16mb file in the chip with a old 16mb file and your 8mb file in to the chip with the old 8mb file. The other chip with the 2mb file i left intact. It is still bricked, keyboard blinking, power button on and fans rotating slowly. I will try other ram modules. Am I missing something? What is this DMI location I see in others bios thread? Attached some mobo pics just in case. (the 2 soic 8 close to the battery are the 8 and 16mb ones. And the one close to the gpu/cpu is the 2mb weird one)
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11815
                        This is a DMI (device information) added file, the 2MB file is the firmware of the NVIDIA graphics card.
                        • MartinBRM
                          • Jan 2023
                          • 7
                          • Brazil
                          This Nvidia chip is 1.8v (2.5v max) acording to its datasheet. Despite being able to read and re read it, could i have damaged it? (my spi is 3.3v). Also, i 've renamed the files you've attatched cause terminal was complaining, may this cause any issues? And finally, just to be sure, those last bios files you've attached are exactly the same as the previuos?
                          Thx for everything, you've been of great help.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11815
                            You should stop search bios solution anymore, your machine still has integrated Intel graphics card, renaming the bin file does not affect the file content, I said this is the original bios file, it will work when you don't have any other hardware failures.
                            • MartinBRM
                              • Jan 2023
                              • 7
                              • Brazil
                              2 days ago, I`ve unlocked the bios and was messing around with ram timing/voltage and core multiplier, then it bricked. I though hardware damage was hard to do this way and the culprit must be the bios. I guess you are right, must have damaged something. Thanks for your support anyways.
                              • lenopower
                                • Sep 2023
                                • philiipines
                                anyone can help me need bios file for may lenovo legion y7000p2021
                                s/n Pf2ypeh1
                                mtm: 82jk006lcd
                                thnx in advance
                                • peste
                                  • Dec 2016
                                  • 12887
                                  • ROMANIA
                                  s/n Pf2ypeh1
                                  mtm: 82jk006lcd
                                  thnx in advance
                                  did you read this??
                                  • lenopower
                                    • Sep 2023
                                    • philiipines
                                    ok
                                    • nikola07
                                      • Sep 2018
                                      • 36
                                      • Ukraina
                                      How to add dmi to a new dump? Can I give you my one that doesn’t work? Can you help me?
                                        • 21040
                                        Originally posted by nikola07
                                        How to add dmi to a new dump? Can I give you my one that doesn't work? Can you help me?
                                        Sure can,post your backup and the laptop serial number - https://www.badcaps.net/forum/showthread.php?t=103570
                                          Lenovo Legion 5 15ITH6 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion 5 15ITH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ITH6 boardview and 5 15ITH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 04:30 AM
                                        • KowaKowa
                                          Lenovo Legion Slim 5 14APH8 bios dump
                                          by KowaKowa
                                          I'm looking for Lenovo Legion Slim 5 14APH8 bios dump.
                                          Flash memory with bios is damaged and is not possible to recover any information from it.
                                          Model Name - Legion Slim 5 14APH8
                                          MO: PF9XB3C18168
                                          MTM: 82Y50058PB
                                          S/N: PF4VA0QY
                                          On the motherboard itself I can see following identifiers:
                                          KY58A KY58B KY58C KY58J
                                          NM-F301 Rev 1.0
                                          Please let me know if any other informations are needed.
                                          02-18-2024, 03:44 AM
                                        • AHmad_Salal
                                          Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                          by AHmad_Salal
                                          Hello all,
                                          I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                          11-28-2023, 05:28 AM
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                          09-12-2024, 02:30 PM
