Thinkpad L14 gen2 Intel BIOS needed!
  • shiyab
    replied
    Originally posted by sanjaysanthosh
    HI SIR I NEED CLEAR BIOS , THIS BIOS NO DISPLAY , LENOVO THINKPAD L14 GEN 3
    223030-1
    S/N PW05LFTT
    hi try
  • sanjaysanthosh
    replied
    223030-1
    S/N PW05LFTT
  • almirsilvestre
    replied
    Originally posted by hoaca388
    L14 Gen 2 Laptops (ThinkPad) - Type 20X2
    Hi...I saved the 2 bios files you sent me...but the laptop won't turn on...it just has an orange light...when I turn it on with the battery...it has a white light...but it still won't turn on.
    Can you help me?
    Thank you very much for your kindness.​
  • almirsilvestre
    replied
    Thank you very much my friend...I will test it...and I will come back here again to inform you...I thank you very much in advance.
  • hoaca388
    replied
    Originally posted by almirsilvestre
    Hi everyone...how are you? My notebook's BIOS was corrupted during the update...I tried to remove the BIOS to rewrite it and ended up breaking both BIOS chips...I already bought the chips and I need the BIOS files...both for the 2104 chip...and for the 2101
    Notebook model: ThinkPad L14 Gen 2 Type L14 Gen 2 Type 20X2
    Motherboard: HL4A0HL5A0 NM-D271
    Machine Type Model: 20X2SCEE00
    System-unit serial number: PE0BH2RP
    System board serial number: K1BR39K2AW8
    Bios purchased:
    U2101: W25R256JVEIQ
    U2104: W25R128JVPIQ
    Bios chips according to the motherboard datasheet.
    Can someone please help me with these BIOSes?
    Thank you.
    P.S...Sorry for posting twice... I tried to edit the first post but couldn't change it.
  • almirsilvestre
    replied
    Bios purchased:
    U2101: W25R256JVEIQ
    U2104: W25R128JVPIQ
    Thank you.
  • almirsilvestre
    replied
    System-unit serial number: PEOBH2R
    Bios purchased:
    U2101: W25R256JVEIQ
    U2104: W25R128JVPIQ
    Thank you.
  • Mahesa09
    replied
    Originally posted by VUONG MAI
    Re: Thinkpad L14 gen2 Intel BIOS needed!
    are you sure that u2104 chip is installed from factory or you installed it yourself. i have the same motherboard with the same color but no chip
    It's work. Thank you very much !
    are you sure the
  • brzostos
    replied
    Originally posted by SMDFlea
    The 20X2 has 2 bios chips, 32MB and 16MB. If U2104 is where the 16MB chip should be then you will have to get one.
    I only have the U2101 32MB chip on the board, there is no U2104 and it looks like it was never there.
    replied
    Originally posted by brzostos
    The laptop does not respond to the power button, voltages of 3.3v and 5v are present. On the 3.3v switch it drops to 0 when pressed, charging the batteries.
    After connecting the power supply, the battery charging LED lights up and the power LED flashes 3 times.
    The U2104 chip is not on the board
    ThinkPad L14 Gen2
    SN: PF2Z52EC
    Type: 20X2-S0DL00
    NM-D271 REV 1.0
    The original upload looks damaged to me because it is very different from the ones I downloaded here.
  • brzostos
    replied
    Originally posted by kalilinux25
    Can you please try this???
    This is just a dump for kbc and I need the main bios.
  • kalilinux25
    replied
  • brzostos
    replied
    ThinkPad L14 Gen2
    SN: PF2Z52EC
    Type: 20X2-S0DL00
    NM-D271 REV 1.0
  • kalilinux25
    replied
    Originally posted by korsa74
    hello can you clean this pleaaaaaaase : )
    HL4A5/HL5A5 NM-D391
    REV / 1.0
    type number : 20x8-s0a700
    serial number : pf-3p4wc6
    please try
    replied
    HL4A5/HL5A5 NM-D391
    REV / 1.0
    You MUST:
    • Post what the problem is, be specific, - black screen, no boot, running slow, password.Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
  • korsa74
    replied
    HL4A5/HL5A5 NM-D391
    REV / 1.0
  • alyack
    replied
    I have corrupted bios, I tried several bios, but the disk (M2 SSD) does not work with any of them, then I officially updated the bios and it still does not work.
    Thank you very much for your help:
    Model L15 Gen2
    PF-366VGX series
    TYPE NUMBER 20X4-S68000
    Factory ID: JVHFC1
    Compliance ID:
    TP00121F2
  • carlucci
    replied
    Originally posted by nolimit
    Hello, with with programmer i can read and writh L14 Gen2 - NM-C741?
    use this one:
    SFLY SP20P and also adapter QFN8 socket to DIP8 adapter 5x6 and 8x6.
  • carlucci
    replied
    Re: Lenovo ThinkPad L14 Gen2 - NM-C741 Rev 1.0
    You can try the BIOS from Post #18, your BIOS is divided into 2 chips and you have to program both chips together.
    Hi.
    Will it be possible to explain to me how I program these two chips, maybe I am doing something wrong.
    I have here two motherboards one is working and have i5 chip and only 1 bios. I took the opportunity to read the voltages of this one to check the other one that doesn't turn on.
    The other have i7 chip and the bios chip location is u2101 the rom model is mx77l256sqfz and have second rom chip near I/O, location u2104, the model chip is w25q128jvpq.
    it is so close to the I/O that I thought it was an EC, but the schematic indicates that it is a second bios...so I'm stuck here.
    Best Regards,
  • nolimit
    replied
