Dell Latitude 5420 Bios Password 8FC8
    Re: Dell Latitude 5420 Bios Password 8FC8
    Originally posted by strujaze View Post
    Hi every one i have dell latitude 5420 i5 11gen LA-K491P REV 3.0 locked bios 8FC8,please help
    try..
      Originally posted by Alatar3791 View Post
      Would anyone be kind enough to help me? In a brilliant stroke of idiocy I accidentally set my admin, system, and HDD to random passwords with Dell Command and Configure.
      I need to remove the system password, administrator password, HDD password, and Computrace.
      Model: Dell Latitude 5420
      Service Tag: JSYN5J3-8FC8
      Chip: XMC25RH256CXIQ
      Board: GDF40 LA-K491P Rev: 2.0 (A01)
      Thanks in advance.
      remove administrator password only
      Try...
        Try...
        Flashed file and device is now unresponsive except the battery light will illuminate amber while the power button is pressed but only if AC power is connected, otherwise completely unresponsive; no fan spin up, no display, no lights, etc.
        Re-flashed locked file and device turns on fine but obviously also is still locked.
        Flashed the patched file again and again device unresponsive.
        The flash file's CRC32 matches what was written and then read back and the old locked bios was correctly written back on to the chip so it doesn't seem to be an issue with my programmer or settings. Further assistance would be greatly appreciated.
          patched file from Ghamidi is ok, check if you solder chipset properly. Let it run for 2 minutes, it will restart several times with no display. Don't forget to remove CMOS battery.
            Dell Latitude 5420 with password
            hello friends
            i have Dell Latitude 5420 with password can any ONE unlock this BIOS please
            Dell Latitude 5420 i5 11 GEN 14″
            https://***********/vGrY/download/Rcpg3R2****
            [Mod. Edit-Vesko356] Read the rules please! You must attach files directly to your post instead of linking to external websites!
              Re: Dell Latitude 5420 with password
              Originally posted by aze2eza@gmail.com View Post
              hello friends
              upload bios dump here.
              Last edited by Vesko356; 08-15-2023, 11:58 AM. Reason: Quoted external url removed.
                thank you for help
                  thank you for help
                  Hi, here is your unlocked file.
                    Thank you so much for your help it is work
                      Hi guys, how do you patch locked bios file to unlock?
                        read bios guides and threads, ALL is in there ...
                          have tried dell 5420 11th gen but failed
                            here
                              here
                              Thank you..working
                                Hello brothers
                                I need unlocked BIOS for dell latitude 5420 and I've attached old BIOS bin file.
                                MODEL NO: DELL LATITUDE 5420
                                SERVICE TAG: 518LBK3
                                PART NO: LA-K491P
                                Thankyou
                                  Originally posted by Kesavan View Post
                                  Hello brothers
                                  PART NO: LA-K491P
                                  Thankyou
                                  Always asking,never giving.....
                                  If you study a locked and unlocked bios with a hex editor you`ll get an idea how to do it.
                                    So, another one to blacklist ...
                                      try..
                                      Thank you so much for your help it is work perfectly
                                        Re: Dell Latitude 5420 Bios Clean
                                        Hi can any one pls help me clean this bios sometimes I get a amber power led but generally powers on but no display was working just went off and now no display. thanks Dell Latitude 5420 11TH GEN I5 service tag is 6M5TWD3
                                          Latitude 5420
                                          Service Tag: 6M5TWD3
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
