Bin file for Samsung R525 BIOS
  • nahidmirzayev
    • Jan 2022
    • 5
    • Azerbaijan
    Dear friends,
    I need bin file for Samsung R525 BA41-01196A. I found several ones in the internet, but couldn't make it work. When I try to flash it (chip labelled 05NS -number U512) with programmer there are three chips (W25A80BL, W25A80BV, W25A80JV) and I don't know which one to write in.
    Could you please, help to solve it.
    Problem of the notebook is - power, touchpad leds come up, fan works, no display
    Thanks in advance
    Sincerely
    Nahid Mirzayev
    • 22279
    Re: Bin file for Samsung R525 BIOS
    Originally posted by nahidmirzayev
    Dear friends,
    Thanks in advance
    What model is your programmer. Don`t use auto-detect ,select the chip manually. The chip part number is etched on it.
    • nahidmirzayev
      • Jan 2022
      • 5
      • Azerbaijan
      My programmer is CH341. I use NeoProgrammer software. I select manually but there 3 options as I mentioned in my post. There was a label on the chip I removed it but couldn't read its number
      Sincerely
      Nahid Mirzayev
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Citymin
        Samsung NT750QCJ or NP750QCJ(Galaxy Book Flex Alpha) Bios File Please.
        by Citymin
        HI all.
        I need Bios dump File for
        NT750QCJ or NP750QCJ(Galaxy Book Flex Alpha - 15inch).
        My Samsung Galaxy Book laptop Flex Alpha has no display and won't boot.
        09-14-2025, 06:12 PM
