ThinkPad X380 la-f421p rev 1.0
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1355
    • France
    #61
    otherwise 4Matic mod with your informations if you Ec is corrupted
    • FalconPunch
      • Oct 2023
      • 23
      • France
      #62
      Originally posted by Maxpower3
      why not put back your original dump. I cleaned it
      Ah why not I will test the two EC file . I feared to make any more mistakes now that PC finally boots ^^'
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1355
        • France
        #63
        only the modified 4matic. Yours is always weird​
        • FalconPunch
          • Oct 2023
          • 23
          • France
          #64
          Update : got a bit sick. Computer is working no problem : I had the choice to permently disable computrace (which is done ) and supervisor password is disabled with no errors thanks to MaxPower EC file . The working bios for x380 is from 4Matic (Thanks). I managed to learn a bit from the dump provided. So i am assuming that computrace are those two 60 on adress 00000200 which needs to be zeroed out in order to have the choice to remove computrace. Supervisor password is disabled from zeroing out from adress 00000210 to adress 00000230 approximatively (I uploaded a binary diff between the original EC file and the one provided by MaxPower). As a bonus, I also read the EC chip when computrace has been set to permanently disabled beforehand (I uploaded the binary diff between MaxPower EC and the one read on the EC chip). Last thing here , are all the EC file in a compressed archive for ressearch purposes. Thanks for all the help given.
          Click image for larger version  Name:	EC original vs no password no computrace.png Views:	0 Size:	257.3 KB ID:	3578893
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            #65
            @FalconPunch Feeling happy to be a part of this thread & laptop is back to life maxpower You are awesome i have seen in lenovo there is no one and no comparison with you man.............. keep growing
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1355
              • France
              #66
              I managed to learn a bit from the dump provided. So i am assuming that computrace are those two 60 on adress 00000200 which needs to be zeroed out in order to have the choice to remove computrace. ]
              lost, what you think is computrace, is the checksum of each line of the password.
              I will come back tomorrow for that.​
              • FalconPunch
                • Oct 2023
                • 23
                • France
                #67
                thanks i intend to do so
                Also here are the EC files that should have been uploaded in my previous post for ressearch purposes (and also works no problem)
                • FalconPunch
                  • Oct 2023
                  • 23
                  • France
                  #68
                  Gosh, i am bad at sinking ship games, Ill need to check the other EC files i have
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1355
                    • France
                    #69
                    on the double file, you must take 2 lines
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1355
                      • France
                      #70
                      Computrace is enabled .
                      About Computrace: It was not previously enabled on your machine.
                      when you did your tests with my technique or when you entered the bios the first time with it was not present.
                      this was only declared with the gayvum file or mine post#47??
                      already no trace in your bios.
                      Click image for larger version  Name:	image.png Views:	0 Size:	10.7 KB ID:	3579232
                      Second, I've encountered this problem before on a PC that doesn't have Computrace enabled.
                      But when I corrupt the data it activates
                      Click image for larger version  Name:	image.png Views:	0 Size:	1,011.1 KB ID:	3579233
                      we also notice, if we compare the files
                      that it is filled with FF while this one should contain 00s here.
                      Click image for larger version  Name:	image.png Views:	0 Size:	257.9 KB ID:	3579234
                      causes errors code 0188 + 0189 and 0177
                      0177 for checksum stories, explained above
                      0188 + 0189
                      if I don't talk nonsense these 2 lines
                      creates RFID errors
                      Click image for larger version  Name:	image.png Views:	0 Size:	154.8 KB ID:	3579235
                      what becomes interesting now is if we compare my file with the one you deactivated computrace .
                      value has changed for the last 4.
                      I haven't yet fully understood these lines but we can spot them because there are always 4 bytes on one and 4 on the other side with 00s in the middle
                      • FalconPunch
                        • Oct 2023
                        • 23
                        • France
                        #71
                        Maxpower3 , Initially when the bios booted and displayed invalid information (Indeed , i flashed the bios from 4Matic and your EC file at post #47 ) , I had computrace set to enabled and greyed out. Also at the beginning, before I was trying the LPC AD with short to ground method, computrace was also set to enabled. (Also thanks for your exhaustive explanation)
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1355
                          • France
                          #72
                          Maxpower3 computrace was also set to enabled. (Also thanks for your exhaustive explanation)
                          yes I saw that you had talked about computrace before, I thought it had appeared after the tests.
                          now, what helped to sober it up if it was still present with the files provided?
                          another bios and Ec but always present . weird
                          • FalconPunch
                            • Oct 2023
                            • 23
                            • France
                            #73
                            Yeah, kind of a mystery case at the end on this one
                            • spacez
                              • Nov 2023
                              • 69
                              • FR
                              #74
                              HELLO X380 not power . only fan and keyboard lights on for some secondes . kindly fix my issues . thanks
                              Lenovo ThinkPad X380 yoga
                              DTZS1 LA-F421P Rev 1.0
                              SN MP-1MG844 19/09​
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12330
                                #75
                                SN MP-1MG844 19/09​
                                No bios for Chromebooks on Lenovo homepage.
Name:	2025-03-11 17_32_53-chromebook laptops __ lenovo chromebooks series __ 14e chromebook __ 81mh __ 81m.png
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1355
                                  • France
                                  #76
                                  MP1MGF1A
                                  Bios and Ec version 1.29 R0SET45W/R0SHT45Wcertainly
                                  Click image for larger version  Name:	image.png Views:	0 Size:	247.9 KB ID:	3590763
                                  • spacez
                                    • Nov 2023
                                    • 69
                                    • FR
                                    #77
                                    thnak you Maxpower3; for correction and . the sticker was bad .and cant seen letters. sorry
                                    so again ??
                                    SN MP1MGF1A
                                    • BHK912
                                      • Oct 2025
                                      • 6
                                      S/N: MP1HR11S
                                      I have a Thermal Sensing Error.
                                      Plz help me to fix this issue.
                                      Thx
                                      • LBTT1121
                                        • Nov 2024
                                        • 995
                                        • Việt Nam
                                        #79
                                        S/N: MP1HR11S
                                        Thx
                                        try and feedback
                                        • BHK912
                                          • Oct 2025
                                          • 6
                                          thank you LBTT1121, but still same problem.
                                            Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X380 Yoga boardview and X380 Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 02:28 PM
                                            09-06-2024, 01:21 PM
                                            09-06-2024, 12:51 PM
                                            09-06-2024, 11:50 AM
