latitude 5420 board LA-k491P bios problem.
  • chelsea1155
    replied
    Originally posted by LBTT1121
    try and feedback
    STILL REPORTING TPM ERROR
  • LBTT1121
    replied
    try and feedback
  • chelsea1155
    replied
    Originally posted by RJ_TECH
    try
  • RJ_TECH
    replied
    PLEASE FIX MY BIOS TPM ERROR
    Dell latitude 5420
    st: BD404J3
    LA-K491P
    try
  • chelsea1155
    replied
    Dell latitude 5420
    st: BD404J3
    LA-K491P
  • hoaca388
    replied
    PLEASE HELP ME FIX THE BIOS FILE
    Dell latitude 5420
    st: BHJP6J3
    LA-K491P
    Latitude 5420
    Service Tag: BHJP6J3
  • chelsea1155
    replied
    Dell latitude 5420
    st: BHJP6J3
    LA-K491P
  • hoaca388
    replied
    Originally posted by Omar Villalba
    I'm having the following issue: I tested this BIOS and the system boots up without any problem, but when the operating system starts, the BIOS gets updated and the computer stops turning on, only showing the message "BIOS CORRUPTED."
    Has anyone else experienced this issue?
    DELL LATITUDE 5420
    GDF40 LA-K491P
    Rev: 2.0 (A01)
    PWB: 2FM7C
    ST: F4243F3
    I'm attaching the original BIOS.
    Latitude 5420
    Service Tag: F4243F3
  • Omar Villalba
    replied
    Originally posted by bachir2004
    Re: latitude 5420 bord LA-k491P bios problem.
    ok.see pm.
    DELL LATITUDE 5420
    GDF40 LA-K491P
    Rev: 2.0 (A01)
    PWB: 2FM7C
    ST: F4243F3
  • Laboratorio JG
    replied
    Originally posted by Laboratorio JG
    HI, COULD YOU HELP ME WITH THIS BIOS? IT SHOWS A TPM ERROR AND HAS AN ADMINISTRATOR KEY? CAN YOU HELP ME PLEASE?
    BOARD MODEL: GDF40 LA-K491P REV 2.0(A01)
    2020-11-16
    DELL MODEL: LATITUDE 5420
    ST: 4X036D3
    Could someone please help me, I've tried other bios and it doesn't work, could you help me with the one I sent please?
  • devp62
    replied
    Hi Hope someone can help me , I have a latitude 5420 that came in with a damaged chip as someone has has a go at repairing the laptop.
    I have replaced the chip and reprogramed it but now the machine come to life but gets stuck at the dell logo and get the 3 amber x6 white led flash, the old chip had a hole init so cant read any thing off it.
    Can some on help pls
    St: 6RKDJQ3
    Latitude 5420
    Motherboard model :-GDF-40 LA-491P Rev 2.0 ( A01 )
  • peste
    replied
    Originally posted by saudi_ma
    I have a Dell Latitude 5420 (tested without HDD) and I’m running a diagnostic tool such as Aiken Workbench. The problem is that the tool detects the onboard LAN card, but it shows the message:
    "no working driver for it"
    and the test result is NO Driver.
    Interestingly, when I install Windows, the LAN card works perfectly fine, which confirms that the hardware itself is okay. I have tried multiple cables and diagnostic environments, but the result is the same.
    For comparison, I have a BIOS dump from a working unit and another from the problematic unit. The file sizes are identical. I suspect the issue might be related to a missing or corrupted PXE/UEFI network driver module in the firmware.
    My questions:
    • Has anyone experienced this issue before?
    • What are the recommended steps to add the proper LAN driver to a diagnostic/WinPE environment, or to safely repair the firmware?
    • If no solution can be found, I would appreciate it if any expert who knows how to fix this fault could contact me privately to suggest the right approach.
    Thank you in advance for your help.
    post S/T, full name and model, motherboard model, ,etc.
    post the contents of the bios chip even if it is corrupted..
  • peste
    commented on 's reply
    post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
  • saudi_ma
    replied
    My questions:
  • Laboratorio JG
    replied
    2020-11-16
    ST: 4X036D3
  • modd1uk
    replied
    Hi guys, I have a latitude 5420 here, I've done a few but this one is proving to be an issue.
    Chip resoldered, laptop boots but NVME not detected, from a bit of reading this could be a corrupt ME region?
    Can anybody help please?
    I have uploaded the original locked dump, so if somebody could remove the admin password and repair the ME I would be forever grateful, thank you.
    Dell Latitude 5420
    ST - 90517M3
  • kumar1144
    replied
    Originally posted by hoaca388
    File is corrupted
    any alternate file please,
    Dell Latitude 5420,
    Service TAG-9QZF3F3,
    2021-10-15.
    Here I attached bios which i got from badcaps, in this bios dell logog coimg after blank display. kindly help me with thiss. in this bios TPM not Detected error kindly fix this
  • hoaca388
    replied
    Originally posted by kumar1144
    Hi in this bios TPM Error , dell logo hang, green, red, blue, white screens coming
    Kindly anyone fix This
    Dell Latitude 5420,
    2021-10-15.
    Thank You in advance
    File is corrupted
  • kumar1144
    replied
    Dell Latitude 5420,
    2021-10-15.
  • modd1uk
    replied
    I successfully removed the admin password with the 8FC8 patcher (although it seems to change entries in more than two locations?).
    I was under the impression the 8FC8 patcher only edited two strings, when I use it on this dump it edits 4.
    Dell Latitude 5420
    ST - 90517M3
  • TripTop
    Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
    by TripTop
    Hi
    i have dell latitude E7270 with following symptoms:
    - takes long time to restart.
    - sometimes powers on and then off
    - sometimes while working it just dies,
    From googling online bios clean could possible resolve this?
    i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
    As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
    I reinstall...
    09-09-2024, 02:05 PM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
    DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
    09-07-2024, 06:31 AM
    09-07-2024, 03:40 AM
