Panasonic FZ-G1 DFUP2171ZD bios need
  • akdenizmusty
    • Aug 2016
    • 46
    • Turkey
    device turns on and stays on black screen.I am sharing the old bios. There is a bios file on the site but I don't know how to open the exe file.
    Motherboard: DFUP2171ZD
    • 22188
    Re: Panasonic FZ-G1 bios need
    https://dosya.co/gviiqva4mdfq/Fz-G1.rar.html
    Post your file here in a zip or rar .Images should also be posted here and not to an external image host.
    • akdenizmusty
      • Aug 2016
      • 46
      • Turkey
      I already shared the file. I will pay attention to the other details
      • akdenizmusty
        • Aug 2016
        • 46
        • Turkey
        Re: Panasonic FZ-G1 DFUP2171ZD bios need
        anyone ?
          • 22188
          anyone ?
          Can you post the link to the exe update you found
          • akdenizmusty
            • Aug 2016
            • 46
            • Turkey
            I managed to open the exe and edited the bios, tried it and it worked. I am sharing the working file. Thank you for you attention SMDFlea
            • to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
              by to5it0
              Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
              I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
              This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
              I have opened the laptop and identified the main BIOS chip...
              10-24-2025, 01:35 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • maanee11
              Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
              by maanee11
              Hello Everyone,
              I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
              It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
              In the website, you can only see specs etc.
              I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
              11-08-2025, 04:08 AM
            • m1ch43lzm
              Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
              by m1ch43lzm
              Hi everyone
              I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
              Programmer models: XGecu TL866II Plus / T48 / T56 / T76
              Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
              There's also an extra OTP Secu.R...
              09-06-2025, 05:47 PM
            • Forest79
              by Forest79
              However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
              07-23-2023, 07:39 AM
