ACER FH52M LA-J891P REV 1B bios
  • Marc97
    • Jan 2016
    • 189
    • Phillipines
    good day,,, Can someone have good file for this acer
    predator Helios 300
    PH315-53-57VP
    Board model FH52M LA-J891P REV 1B
    i attached the back up file no power...
    i already download bios from acer site and create bin via ************** (It goes to power up but no display)
  • Aditya11ttt
    Adi
    • Feb 2019
    • 192
    • India
    Re: ACER FH52M LA-J891P REV 1B bios
    predator Helios 300
    PH315-53-57VP
    i already download bios from acer site and create bin via **************** (It goes to power up but no display)
    is this og bios ?
    • Marc97
      • Jan 2016
      • 189
      • Phillipines
      Originally posted by Aditya11ttt
      is this og bios ?
      yes it is the original
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Predator PH315-53-FH53M
        • Marc97
          • Jan 2016
          • 189
          • Phillipines
          thank you i will update if it works on me
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • Danfay
            Acer Aspire 3 A317-51G Request Bios in .bin file
            by Danfay
            Hello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
            Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong . The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file .
            The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
            So I updated to version 1.11, which apparently either went wrong or is not functional.
            Does anyone...
            09-25-2023, 02:57 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
