820-02016-a bios help
  • jaglion19
    • Oct 2017
    • 102
    • TURKEY
    I'm so sorry for the bad english. I have attached the original bios dump to 820-02016-a. There is no firmware password but after the install it asks for ID, does anyone have a bios dump with another serial number or can someone help me change the serial number?
    :keman:
  • peste
    • 13422
    • ROMANIA
    Re: 820-02016-a bios help
    :keman:
    the bios is corrupt..check and post again ..post the full name and model...EMC...S/N..etc...give more details..
    • jaglion19
      • Oct 2017
      • 102
      • TURKEY
      I know it's a2337 2020, it's been waiting for a long time, macbook air 13”, I couldn't find the serial number in the bios, I would appreciate if you add a suitable bios dump for it, I want to change the 5th letter of the serial number and add it. The bios may be corrupted because they tried to bypass with checkm8 before and tampered with it,
      • peste
        • 13422
        • ROMANIA
        post EMC, serial number S/N, model according to the sticker on the case...
        • tareqd60
          • Mar 2021
          • Denmark
          Hi Sir,
          Is it possible to help me get bios file for A2337 820-02016-A?
          SN: C17gd35sq6l4
          EMC 3598
          Thank you so much for your help
          • tareqd60
            • Mar 2021
            • Denmark
            Sorry this is the attached file regarding to privios resquest.
            • peste
              • 13422
              • ROMANIA
              what is the problem with the laptop??
              • borma
                • Jun 2018
                • turkiye
                Hello, I need A2337 EMC 3598 Bios file.
                The computer does not turn on.
                The original file is attached.
                File size 8MB​
                • peste
                  peste commented
                  Editing a comment
                  post merged..
              • peste
                • 13422
                • ROMANIA
                File size 8MB​
                post the S/N, the motherboard model, etc.
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • greelidd
                  K6604J Vivobook RTX 4070 BIOS Dump Request
                  by greelidd
                  Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                  Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                  09-01-2025, 06:14 PM
                • TacticalFahrrad
                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                  by TacticalFahrrad
                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                  06-30-2025, 04:09 AM
                • gabrieljma1
                  Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                  by gabrieljma1
                  I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                  The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                  I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                  10-08-2025, 03:32 PM
