need bios dell latitude 5400 chromebook. LA -H771P
  • krogs214
    • Sep 2017
    • 81
    • Philippines
    #61
    Dell Latitude 5400 chromebook
    Board Number: EDB46 LA-H771P REV 2.0
    SERVICE TAG ALREADY FADED / REMOVED
    • volinakis
      • Jan 2021
      • 2616
      • N/A
      #62
      after write new bios reinstall from USB stick made with Chromebook Recovery Utility for your model. Serial is 3BBFDB3
      • krogs214
        • Sep 2017
        • 81
        • Philippines
        #63
        thank you, il try it now
        • hanz07
          • Oct 2021
          • 18
          • phillipeness
          #64
          hi please can anyone remove or unlock company user?
          LATTITUDE 5400 CHRIMEBOOK
          S/N 8Z2Q493
          LA-H771P
          THANK YOU SIR
          • airblade
            • Jan 2019
            • 58
            • Home
            #65
            ST JJT7C3
            please unlock thank you​
            • volinakis
              • Jan 2021
              • 2616
              • N/A
              #66
              ST JJT7C3
              • vince2746
                • Mar 2023
                • 7
                • philipines
                #67
                hi pls help..
                Dell Latitude 5400 Chromebook
                Board Number: EDB46 LA-H771P REV 2.0 (A01)
                ST : FBST2T3
                • volinakis
                  • Jan 2021
                  • 2616
                  • N/A
                  #68
                  Originally posted by vince2746
                  hi pls help..
                  ST : FBST2T3
                  after write new bios reinstall from USB stick made with Click image for larger version
Name:	Screen Shot 2024-08-10 at 13.25.03.png
ID:	3326364 Chromebook Recovery Utility for your model.​
                  • vince2746
                    • Mar 2023
                    • 7
                    • philipines
                    #69
                    thank you so much.. it works
                    • volinakis
                      • Jan 2021
                      • 2616
                      • N/A
                      #70
                      you are welcome
                      • ellokillox
                        • Mar 2024
                        • 3
                        • Argentina
                        #71
                        you are welcome
                        hi friend sorry to bother you, i have a dell 5400 which i also want to flash its bios to remove enterprise lock. the only chip i see in the board which looks like a bios is a gigadevice chip, but it has a 1mb dump. i cannot find another chip that could have a 32mb capacity, can u help me find it? any tips? or is it all in the same chip?
                        • peste
                          • Dec 2016
                          • 12230
                          • ROMANIA
                          #72
                          look on both sides of the motherboard..
                          • ellokillox
                            • Mar 2024
                            • 3
                            • Argentina
                            #73
                            found it, its a winbond 25Q256JVEM
                            Now problem is that my clamp wont pick this one, maybe i will have to desolder, then dump it here, im not confident on my soldering to do this i need to find a different clamp.
                              SMDFlea commented
                              Editing a comment
                              If the chip is WSON8 use a WSON pogo adapter.There are different ones depending on the chip size.
                          • Akwasi
                            • Jun 2018
                            • 17
                            • ghana
                            #74
                            please help me to remove enterprise account login.
                            PCB: EDB46 LA -H771P Rev.2.0 (A01)​
                          • Akwasi
                            • Jun 2018
                            • 17
                            • ghana
                            #75
                            Service tag : CBXJ8C3
                            • Akwasi
                              • Jun 2018
                              • 17
                              • ghana
                              #76
                              I've added the service tag here. I tried to use hex editor to change enrolment check to 0 but it didn't work. I need either assistance as to how to mod the bios or a mod of the original posted below.
                              • ellokillox
                                • Mar 2024
                                • 3
                                • Argentina
                                #77
                                SMDFlea
                                do i need to power the motherboard (or entire chromebook) in order to be able to read the chip? im trying to read with the new clamp but i got a message saying "check settings"
                                • markenero3
                                  • May 2023
                                  • 25
                                  • Philippines
                                  #78
                                  Good day everyone i have Dell lattitude 5400 chrome laptop with enterprise enrollment lock Please help me to unlock it thank you in advance here is my binπŸ˜€
                                  PCB: EDB46 LA-H771P rev 2.0 (A01)
                                  Service tag: 6WN6273
                                  • volinakis
                                    • Jan 2021
                                    • 2616
                                    • N/A
                                    #79
                                    • markenero3
                                      • May 2023
                                      • 25
                                      • Philippines
                                      #80
                                      Thank you so much sir 100% working <3
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                        11-02-2024, 04:19 AM
                                        DELL Latitude 5400 Chromebook 5000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude 5400 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                        09-06-2024, 07:20 PM
                                        09-06-2024, 04:40 PM
