need bios dell latitude 5400 chromebook. LA -H771P
  • volinakis
    • Jan 2021
    • 2871
    • N/A
    #81
    Originally posted by markenero3
    Thank you so much sir 100% working <3
    You are welcome
    • teptronics
      • Sep 2021
      • 17
      • philippines
      #82
      May i know why my orignal dump bios is only 1024kb? I cant write the bios that are 32mb on size.
      • volinakis
        • Jan 2021
        • 2871
        • N/A
        #83
        look on the backside of motherboard, you'll find bios chipset
        • teptronics
          • Sep 2021
          • 17
          • philippines
          #84
          thanks for the response.. i saw it now, I thought it was the AMIC chip in front of board.
          • its service
            • Feb 2021
            • 142
            • india
            #85
            Dell latitude 5400 chrome
            service tag7FJDK13
            Dell latitude 5400 chromebook to windows 10 help
            Does anyone knows how to unlock R/W of firmware in this dell chromebook? I wanna convert it to windows but i cannot flash UEFI. The bios also have admin locked. Can someone modify my bios bin that i can directly install windows 10?​
            • gctdpacov
              • Nov 2022
              • 43
              Dell Latitude 5400 Chromebook enterprise lock removal help pls.
              Service Tag: C7LR8C3
              Attaching locked Bios
              • volinakis
                • Jan 2021
                • 2871
                • N/A
                #87
                read again bios chipset, it has errors. Read 2-3 times and compare results, when you have 2 identical it means you have a good backup.
                • gctdpacov
                  • Nov 2022
                  • 43
                  Bios attached
                  • volinakis
                    • Jan 2021
                    • 2871
                    • N/A
                    #89
                    Bios attached
                    reinstall using USB stick made with Chromebook Recovery Utility for your model if reset doesn't work.
                    • gctdpacov
                      • Nov 2022
                      • 43
                      No power on.can you pls repair the BIOS
                      • volinakis
                        • Jan 2021
                        • 2871
                        • N/A
                        #91
                        check soldering of bios chipset.
                        • gctdpacov
                          • Nov 2022
                          • 43
                          I tried another bios from forum.Power on with Blank display.I read the bios using clip i think my original bios corrupted.Any way to check the bios for errors.Thanks in advance
                          • volinakis
                            • Jan 2021
                            • 2871
                            • N/A
                            #93
                            I told you before to read it many times and compare results, when you have 2 identical post it to modify it.
                            • ntkkmr110
                              • Feb 2025
                              • india
                              #94
                              BIOS have Enterprise lock. Can You Please help me to remove password .
                                • 21586
                                Read https://www.badcaps.net/forum/troubl...before-posting ,and post the service tag
                                • ntkkmr110
                                  • Feb 2025
                                  • india
                                  #96
                                  Originally posted by SMDFlea
                                  Service Tag: HWST8C3
                                  • krogs214
                                    • Sep 2017
                                    • 84
                                    • Philippines
                                    #97
                                    Hi please help to remove the enrollment enterprise
                                    Dell 5400 chromebook
                                    Service tag HKFN473
                                    thanks in advance
                                    Last edited by krogs214; 03-10-2025, 06:34 AM. Reason: first upload corrupted file
                                    • azanwaqas771
                                      • Feb 2019
                                      • 48
                                      • Pakistan
                                      #98
                                      hi everyone have windows bios dell latitude 5400 LA-H771P if anyone have plz share and thanks in advance
                                      • volinakis
                                        • Jan 2021
                                        • 2871
                                        • N/A
                                        #99
                                        Service tag HKFN473
                                        thanks in advance
                                        try. Reinstall from usb stick if reset doesn't work.
                                        • fkabalos
                                          • Jun 2021
                                          • 5
                                          • Philippines
                                          #100
                                          please help remove enrollment enterprise
                                          Service Tag: 2FFS493
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                            DELL Latitude 5400 Chromebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 5400 Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5400 boardview and 5400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5400...
                                            09-06-2024, 07:20 PM
                                            09-06-2024, 04:40 PM
