Lenovo Legion Pro NM-D562 Rev. 3.0
  • nicoleb2004
    • Jun 2019
    • ROMANIA
    #81
    thank you but i still dont have picture.
    Can you help me more pls?
    Many Thx
    • Andreyvtb
      • Jul 2022
      • 3
      • Belarus
      #82
      Originally posted by highpulse
      Heu guys, long time no post !
      i'm with the same model above nm.d562 board on the bench , and need to flash the it8176FN that is altough a 56KB file , atention that its not the 192EC file , that IT is flashed via the main bios once its updated "! so if someone have the correct file for UI22 , i apreciate if someone can send me that file .
      thk in advance
      try this
      • Andreyvtb
        • Jul 2022
        • 3
        • Belarus
        #83
        Originally posted by FrozenHaxor
        Very doubtful they did that, inspect the board. Lenovo are notoriously hard to do this on due to the black epoxy underfill used on BGA components. BGA desolering in this case usually results in delaminated board and ripped pads along with lifted traces.
        A week ago I also changed the processor on this board. Flashing the BIOS did not solve the problem.
        • nbrepairs
          • Mar 2016
          • 9
          • Bulgaria
          #84
          Greetings.
          Need bios+EC for Legion 5 Pro 16ACH6H
          M/B: NM-D562 rev. 3.0
          S/N: PF38JY7Q
          Laptop is after repair, can't attach main bios - IC is faulty. Also uncertain if EC is also correct, attaching.
          Thanks in advance.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11327
            • Viet Nam
            #85
            Originally posted by nbrepairs
            Greetings.
            S/N: PF38JY7Q
            Thanks in advance.
            Your file is not an EC file, it is NVIDIA's.
            • nbrepairs
              • Mar 2016
              • 9
              • Bulgaria
              #86
              True, my bad, got confused because of its location on the MB also in a hurry.
              So someone has eventually re-programmed nvidia's bios as well, or at least worked on it.
              Need main bios + eventually Nvidia's if even possible, not going to re-program the controller.
              Main bios is the priority now, to check if laptop is going to initialize at all.
              Thanks in advance.
              • kevin1386
                • Nov 2014
                • 6
                • Jamaica
                #87
                WINDOWS 11 UPDATE THEN NO IMAGE DISPLAY ON SCREEN AND ON EXTERNAL MONITOR.
                MODEL NAME: LEGION 5 PRO 16ACH6H
                MOTHERBOARD : NM-D562 REV.3.0
                S/N: PF3FEQ57
                • kalilinux25
                  • Mar 2018
                  • 2069
                  • ZAMBOANGA SIBUGAY
                  #88
                  S/N: PF3FEQ57
                  Here bios rebuild and added serials
                  • kevin1386
                    • Nov 2014
                    • 6
                    • Jamaica
                    #89
                    Thanks for the attempt i tried but the same result no display.
                    • kalilinux25
                      • Mar 2018
                      • 2069
                      • ZAMBOANGA SIBUGAY
                      #90
                      here this a fresh bin form website this will work no dmi or serials
                      • Andok
                        • Oct 2018
                        • 3
                        • Croatia
                        #91
                        Hello.
                        After Windows update laptop can power ON but no picture, FAN not spinnig, No keyboard Light. I dont need DMI data, only working BIOS
                        Ryzen™ 7 5800H Processor(Ryzen™ 7 5800H)
                        NVIDIA® GeForce RTX™ 3060 6GB
                        SN: PF3D4MTC​
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                      • peste
                        • Dec 2016
                        • 12290
                        • ROMANIA
                        #92
                        post the full name and model of the laptop.
                        • kalilinux25
                          • Mar 2018
                          • 2069
                          • ZAMBOANGA SIBUGAY
                          #93
                          Originally posted by Andok
                          Hello.
                          SN: PF3D4MTC​
                          here give feedback, always give full details of your laptop
                          • geethmadu
                            • Mar 2023
                            • 32
                            • united kingdom
                            #94
                            I have a Legion 5 Pro laptop with NO Power. When I press the power button, it only shows the green light but no fan spins or any sign of working. when I read the BIOS I get the error as " Main Chip contents are in Misagreement". Can someone please help. I have attached the original BIOS here.
                            Model: Legion 5 Pro 16ACH6H
                            Serial: PF39NJTX
                            Thank you
                            • peste
                              • Dec 2016
                              • 12290
                              • ROMANIA
                              #95
                              Serial: PF39NJTX
                              Thank you
                              you have everything you need at the #35.post..
                              • Fubukio
                                • Sep 2024
                                • 3
                                i have lenovo legion 5 pro 16ach6h. I sadly forgot my bios password and i'm looking now to flash my bios chip to erase the password. I have a CH341 kit with a clamp and im having a hard time locating the bios chip. At first I thought i found it but when i try to read it with neoprogrammer, i didn't find the exact "Part:#" Can someone please help me. Im trying to dump the bios file from the bios chip and then rewrite it with an old one that i have.
                                The chips i managed to found are these:
                                -winbond 25Q16JWNIQ
                                -winbond 74M12JWSIQ
                                i will add some images of the motherboard below.
                                thanks
                                • Jackalt
                                  • Jan 2019
                                  • 6
                                  • Беларусь
                                  #97
                                  legion5 15ACH6H
                                  sn PF3CZ22M
                                  NM-D562 rev 3.0
                                  Help me please​
                                  • piszpunta
                                    • Jan 2019
                                    • 247
                                    • poland
                                    #98
                                    Originally posted by Jackalt
                                    legion5 15ACH6H
                                    sn PF3CZ22M
                                    NM-D562 rev 3.0
                                    Help me please
                                    how to help you​??
                                    • Jackalt
                                      • Jan 2019
                                      • 6
                                      • Беларусь
                                      #99
                                      I set the settings to "only discret", but nvidia is not working and now the screen is black. Me need a BIOS where the settings include two graphics.
                                      • piszpunta
                                        • Jan 2019
                                        • 247
                                        • poland
                                        #100
                                        try
                                          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                          09-12-2024, 02:30 PM
                                          Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          LENOVO Legion T730 Legion i9-9900K Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion T730 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion T730 boardview and Legion T730 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
