Alienware 13 R3 (LA-D581p) BIOS
  • gurj1979
    • 186
    Has anyone got a GOOD working BIOS for Alienware 13 R3 (LA-D581p) ?
    Thanks.
    • 21600
    Re: Alienware 13 R3 (LA-D581p) BIOS
    Thanks.
    Post your backups as an attachment, zip or rar .
    • gurj1979
      • 186
      Mine is bad so no point in uploading it.
        • 21600
        Bad in what way, is the chip burnt or your programmer can`t read it .What model is your programmer
        • gurj1979
          • 186
          Corrupt BIOS update. MOSFET popped during update
            • 21600
            post your backup if you can read anything at all from the chip,corrupt or not
            • lngcs
              • Jul 2011
              • 69
              Need bios for Alienware 13 R3
              Hi All, Ive got anlienware 13 R3(La-d581p Rev 1.0), I tried clean me with forum guide but keep error during build. i've attached the original bios. please help.thanks
              • hardware1
                • Sep 2021
                • 2946
                • N/A
                Re: Need bios for Alienware 13 R3
                Here's your New BIOS, try it and give me results.
                Service Tag: GMXLZF2.
                all donations are welcome,
                • lngcs
                  • Jul 2011
                  • 69
                  tried and got same results. turn on no display. only power button has 2 red and 1 blue repeatedly and nothing on screen.
                  • munir100
                    • Dec 2018
                    • 187
                    • uae
                    HI i have Alienware 13 R3 with bios password can any removd password ST -JNG5QQ2 LA-D581P
                    • peste
                      • Dec 2016
                      • 13343
                      • ROMANIA
                      try..
                      • munir100
                        • Dec 2018
                        • 187
                        • uae
                        THANKS FOR reply laptop not power on and off
                        • peste
                          • Dec 2016
                          • 13343
                          • ROMANIA
                          write the bios with the password back and see what happens..
                          • drux
                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                            by drux
                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                            These models have AMI/Aptio BIOS.
                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                            11-03-2024, 01:18 AM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • Mr.Ultimate
                            Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                            by Mr.Ultimate
                            Hi everyone, hope to get someone to help and modify bios rom for me.
                            I need to disable dedicated nvidia graphics chip permanently.
                            GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                            Ideally if it was disabled from bios at preboot.
                            I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                            08-06-2024, 05:15 AM
                          • Arc717
                            How do I flash bios to an Alienware M16 R1 AMD edition?
                            by Arc717
                            I am trying to downgrade my bios on my Alienware so I can undervolt & overclock my CPU, and overclock my ram. I need to get to bios 1.2.2 for this. Dell doesn't allow downgrades, and their bios file is an exe compiled in c++, so I can't decompile it easily. I am wondering if I can flash the bios manually using a usb flasher. I would like to know if this is possible, and if so, where the bios chip would be. I know flashers are pretty cheap and the bios chip is 8-pin. There are two of these chips only when I open the back panel of the laptop. I'm not sure if there are any on the other side of...
                            05-17-2024, 03:34 PM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
