Alienware 13 R3 (LA-D581p) BIOS
  • gurj1979
    • 190
    Has anyone got a GOOD working BIOS for Alienware 13 R3 (LA-D581p) ?
    Thanks.
    • 22286
    Re: Alienware 13 R3 (LA-D581p) BIOS
    Thanks.
    Post your backups as an attachment, zip or rar .
    • gurj1979
      • 190
      Mine is bad so no point in uploading it.
        • 22286
        Bad in what way, is the chip burnt or your programmer can`t read it .What model is your programmer
        • gurj1979
          • 190
          Corrupt BIOS update. MOSFET popped during update
            • 22286
            post your backup if you can read anything at all from the chip,corrupt or not
            • lngcs
              • Jul 2011
              • 72
              Need bios for Alienware 13 R3
              Hi All, Ive got anlienware 13 R3(La-d581p Rev 1.0), I tried clean me with forum guide but keep error during build. i've attached the original bios. please help.thanks
              • hardware1
                • Sep 2021
                • 2949
                • N/A
                Re: Need bios for Alienware 13 R3
                Here's your New BIOS, try it and give me results.
                Service Tag: GMXLZF2.
                all donations are welcome,
                • lngcs
                  • Jul 2011
                  • 72
                  tried and got same results. turn on no display. only power button has 2 red and 1 blue repeatedly and nothing on screen.
                  • munir100
                    • Dec 2018
                    • 188
                    • uae
                    HI i have Alienware 13 R3 with bios password can any removd password ST -JNG5QQ2 LA-D581P
                    • peste
                      • Dec 2016
                      • 13924
                      • ROMANIA
                      try..
                      • munir100
                        • Dec 2018
                        • 188
                        • uae
                        THANKS FOR reply laptop not power on and off
                        • peste
                          • Dec 2016
                          • 13924
                          • ROMANIA
                          write the bios with the password back and see what happens..
                          • drux
                            Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                            by drux
                            I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                            Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                            These models have AMI/Aptio BIOS.
                            Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                            11-03-2024, 01:18 AM
                          • pirati
                            by pirati
                            10-27-2025, 04:20 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • SCREAM76
                            Alienware m18 R2 Bios pls
                            by SCREAM76
                            Alienware m18 R2 i9 cpu no screen 5 blue 3 red blink
                            I added the original bios. I need a clean me or a new working bios.
                            Alienware m18 R2
                            Servis tag: 4SWZH54
                            Serial: 10455585160​...
                            11-01-2025, 08:32 AM
                          • Mr.Ultimate
                            Alienware 13R3 bios mod request - to disable dedicated graphics (dgpu failure)
                            by Mr.Ultimate
                            Hi everyone, hope to get someone to help and modify bios rom for me.
                            I need to disable dedicated nvidia graphics chip permanently.
                            GPU chip had failed(cracked silicon DIE) and I can only use laptop without failing if I disable nvidia graphics in dev manager (but it still draws power from battery and generates thermal signature.
                            Ideally if it was disabled from bios at preboot.
                            I believe it is possible, because if I attatch external alienware graphics amplifier , laptop at boot will disable dedicated graphics #1 (failed one) and will only boot with AGA...
                            08-06-2024, 05:15 AM
