Help with Macbook Pro 15 Retina mid 2012 stuck in loading screen with Apple log
  • waakye
    • Dec 2018
    • 340
    • Electronada
    Good day everyone,
    Thanks for all the help and support from this community. I really appreciate them.
    I have a MacBook pro Retina 15inch mid 2012 that turns on and get stuck in the loading screen then reboot. There is no sign of liquid damage. The history of this MacBook pro is I got it dirt cheap at a garage sale. so I have no idea about the story behind it.
    I was able to extract the Bios dump and it attached to this post to see if someone knowledgeable could help me if the bios is somehow corrupted.
    SN = C02J5DCRDKQ1.
    Thanks again.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Help with Macbook Pro 15 Retina mid 2012 stuck in loading screen with Apple log
    Originally posted by waakye
    Good day everyone,
    SN = C02J5DCRDKQ1.
    Thanks again.
    try..
    • waakye
      • Dec 2018
      • 340
      • Electronada
      Thanks Peste
      I tried, the Bios you attached and when I turn on the Mac, no chime. Fan spins but screen is black. I did smc reset and PRAM reset still no boot chime.
      • waakye
        • Dec 2018
        • 340
        • Electronada
        Can anyone share a working Bios. board number is 820-3332-A?
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          give some more data... the name and full model of the laptop... A???? and EMC???
          • waakye
            • Dec 2018
            • 340
            • Electronada
            Thanks Peste for responding.
            Hope that the information below will help.
            Apple MacBook Pro 15-Inch "Core i7" 2.3 Retina 2012.
            A1398 (EMC 2512)
            MC975LL/A
            Thanks again!
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              A1398 (EMC 2512)
              MC975LL/A
              Thanks again!
              try..this
              • waakye
                • Dec 2018
                • 340
                • Electronada
                Thanks peste. Now it chimes and boot but it still get stuck at the loading screen and then reboots. maybe I have a different problem other than the Bios.
                I really appreciate your help. I will report back if anything changes.
                • waakye
                  • Dec 2018
                  • 340
                  • Electronada
                  All thanks go to Peste for helping with the Bios bin file. The MacBook is running now after I change the hard drive. Thanks again Peste!!
                  • korben_dallas
                    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                    by korben_dallas
                    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                    MY QUESTION:
                    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                    02-14-2024, 12:23 AM
                  • Bmet
                    MacBook Pro 13 inch A2238 M2 stuck on 5V
                    by Bmet
                    I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                    04-02-2025, 05:02 PM
                  • conghuyms
                    MacBook Air A2179 stuck logo , pls help me !
                    by conghuyms
                    Hey everyone,
                    I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                    When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                    I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                    11-05-2025, 08:30 AM
                  • Rezendes
                    Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                    by Rezendes
                    Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                    I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                    The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                    05-10-2024, 02:18 PM
                  • modtool
                    Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                    by modtool
                    Dear friends,
                    a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                    I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                    I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                    Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                    10-25-2025, 05:09 AM
