Hp probook x360 435 g8 password clear
  • volinakis
    • Jan 2021
    • 2618
    • N/A
    Re: Hp probook x360 435 g8 password clear
    Originally posted by babydoll8867
    forgot to mention, already changed the win key with no good result...
    after you change win key in bios you have to reinstall because installer already registered your win key. Sometimes it works clearing secure keys and put it in setup mode instead of user mode.
    • volinakis
      • Jan 2021
      • 2618
      • N/A
      Originally posted by gagan
      Hi
      Laptop model x360 435G8
      U365 - W25Q256JVEN
      U367 - W25Q256JVEN
      I have attached the original backup file for U365
      But i dont have the original bin for U367, also i dont have the exact same chip rather a replacement chip W25Q256FVEN
      Use files from post #14 but put your SN from back cover
      U365 is EC_ROM
      U367 is SPI_ROM
      is ok to replace W25Q256JVEN with W25Q256FVEN
      • hoaca388
        Badcaps
        • Jan 2022
        • 11161
        • Viet Nam
        Hi
        U365 - W25Q256JVEN
        U367 - W25Q256JVEN
        Luckily you only lost the bios file, if you lose the EC file (U635) there is nothing I can do.
        Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
        • gagan
          • Nov 2022
          • 27
          Do i flash the original EC file and then this file on U367 . Thanks a lot for your help btw really appreciate it
          • hoaca388
            Badcaps
            • Jan 2022
            • 11161
            • Viet Nam
            No, only flash bios.
            • gagan
              • Nov 2022
              • 27
              i did flash the files from #14 before to test, it did not work , so for u365 should it be original file or file from #14
              • hoaca388
                Badcaps
                • Jan 2022
                • 11161
                • Viet Nam
                #27
                The 2 files in #14 worked, you can try both of them, if your device doesn't work it means it has other bugs that haven't been fixed yet.
                • volinakis
                  • Jan 2021
                  • 2618
                  • N/A
                  #28
                  Hoaca is master here, he told you very clear: leave U365 EC_ROM with original content and flash U367 with file Hoaca post it for you.
                  The files from #14 are both working, I flashed myself for test and laptop turned on, did some bios recovery and after that started normally.
                  to change SN open U367 (main bios) with hex editor and serch for hex 48 00 50 00 5F 00 4D 00 55 00 44 and you'll see SN (5CGxxxxxxx)
                  I think writing file from Hoaca MB will enter in MPM and you have a tab in bios to write unique data of laptop. You have to write:
                  Feature Byte: 3X476J6S6b7B7J7M7R7W7maBaQapaqauawbVcAd6dUdpdqeMeTfPguk8mEmVn7nWng.qA
                  Built ID: 21WWPPCT601#SUUW#DUUW
                  Serial: yours from the bottom cover
                  SKU: 4L2E5EC#UUW
                  Product family: 103C_5336AN HP ProBook x360
                  System board CT: PMQYL00WBFX380
                  Product name: HP ProBook x360 435 G8 Notebook PC
                  Name: HP ProBook x360 435 G8 Notebook PC
                  • aldopc
                    • Jul 2017
                    • 464
                    • Chilito
                    #29
                    X360 435 g8 password biosn computrace
                    Plaease Hoaca please helpme
                    • hardware1
                      • Sep 2021
                      • 2887
                      • N/A
                      #30
                      Re: X360 435 g8 password biosn computrace
                      If you only have a password problem, try this file with your EC chip and give me the results.
                      all donations are welcome,
                      • aldopc
                        • Jul 2017
                        • 464
                        • Chilito
                        #31
                        Thanks bro but I don't have a image.
                        • hardware1
                          • Sep 2021
                          • 2887
                          • N/A
                          #32
                          Ok, here's your main too.
                          Be sure that you have soldered the chips correctly.
                          • aldopc
                            • Jul 2017
                            • 464
                            • Chilito
                            #33
                            bro still follow the password
                            • aldopc
                              • Jul 2017
                              • 464
                              • Chilito
                              #34
                              Helpme please
                              • volinakis
                                • Jan 2021
                                • 2618
                                • N/A
                                #35
                                Helpme please
                                Write back U365 with original bin and write this in U367. will enter in MPM and have to write back DMI data. at 1st boot reset security to factory defaults.
                                Feature Byte: 476J6S6b7B7J7M7R7W7mapaqauawbVeMfPguj4k8mEmVn7nWngpnpqpr.tn (no spaces)
                                Built ID: 21WWPPDZ601#SABM#DABM
                                serial: 5CG2090BQS
                                SKU: 63W13UC#ABM
                                System board CT: PLKSR00WBGC01U
                                Then use BCU to exit MPM or restart laptop 30 times or so. (how many times counter shows)
                                NOTE: you better read again U367 , Feature Byte look a bit strange to me, too less characters and should start with 3X
                                • aldopc
                                  • Jul 2017
                                  • 464
                                  • Chilito
                                  #36
                                  serial: 5CG2090BQS
                                  SKU: 63W13UC#ABM
                                  follow the passwords there, also computrace... f. byte is ok, it matches the one written in the cover
                                  • volinakis
                                    • Jan 2021
                                    • 2618
                                    • N/A
                                    #37
                                    did you reset to factory defaults at 1st boot?
                                    • aldopc
                                      • Jul 2017
                                      • 464
                                      • Chilito
                                      #38
                                      if i always do it, apparently there is a backup saved in the other chip,
                                      • aldopc
                                        • Jul 2017
                                        • 464
                                        • Chilito
                                        #39
                                        Solved bro thanks ec clear password and ok.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11161
                                          • Viet Nam
                                          #40
                                          Try
                                            HP ProBook ProBook x360 11 G1 EE Notebook PC Notebook Specification for Upgrade or Repair
                                            This specification for the HP ProBook ProBook x360 11 G1 EE Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook x360 11 G1 EE Notebook PC boardview and ProBook x360 11 G1 EE Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 06:40 AM
                                            HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                            09-07-2024, 05:50 AM
                                            HP ProBook x360 Fortis 11 inch G9 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP ProBook x360 Fortis 11 inch G9 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Fortis 11 inch G9 boardview and Fortis 11 inch G9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
