DAG7BDMB8F0 REV:F bios
  • mferna14
    • Jun 2018
    • 1050
    Hi all, can anyone re-build Hp 15-ca2003ca DAG7BDMB8F0 REV:F BIOS of mine. The motherboard shows the white LED glowing on the DC-in jack & battery charges too but when turned on, the Power LED glows for 3~5 sec & then the MB shuts off. No shorts at all on the MB. Please if anyone can re-build this Original BIOS, thanks in advance.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Hp 15-ca2003ca DAG7BDMB8F0 REV:F shuts off
    HP Pavilion 15-cs2003ca. Serial number : 5CD9301RWH
    • mferna14
      • Jun 2018
      • 1050
      Thank you so much "hoaca388", will try tomorrow morning & will let you know. Appreciate your help
      • mferna14
        • Jun 2018
        • 1050
        I programmed & soldered the BIOS. The status is the same & I think your is working fine. I think there is some other fault too. Thank you so much for the help.
        • rn_baba
          • Dec 2021
          • nepal
          Hello everyone, can anyone re-build Hp 15-ca2003ca DAG7BDMB8F0 REV:F BIOS of mine. motherboard work properly but display not glow. Please if anyone can re-build this Original BIOS,
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Read the rules before posting:
            Upload your original bios backup, serial number...
            Become a Badcaps supporter
            Thanks to all supporters.
            • bel77
              • May 2013
              • 34
              • jordan
              try this orginal
              Last edited by Vesko356; 07-06-2023, 06:21 AM. Reason: Attached bios removed. Thread hijack.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Originally posted by bel77
                try this orginal
                Attached bios in you post is removed. Do not hijack threads! Read the rules at the link in my previous post.
                • mberbouch
                  • May 2014
                  • 109
                  • Morocco
                  Thanks for this dump, I have the same problem, hope it will work.
                  • psinh99
                    • Feb 2015
                    • 54
                    • viet nam
                    Could anyone please help me with this situation: My computer is not detecting either the HDD or the M.2 SSD. If it does detect them, it only happens once, and after restarting, the computer runs but nothing displays on the screen, as if it’s frozen. If I remove the HDD or M.2 SATA, the computer works normally. Could you please help me rebuild my BIOS?
                    Hp 15-cs2035tu
                    S/N#5CD9312SPV
                    DAG7BDMB8F0 REV:F
                    my old bios:
                    I have tried several BIOS versions provided by you, but none of them worked. Thank you in advance.
                    • LBTT1121
                      • Nov 2024
                      • 1239
                      • Việt Nam
                      Hp 15-cs2035tu
                      S/N#5CD9312SPV
                      DAG7BDMB8F0 REV:F
                      my old bios:
                      Hi, try and feedback
                      • psinh99
                        • Feb 2015
                        • 54
                        • viet nam
                        Thank LBTT1121 very much. It works fine
                        • Ziome3eknh
                          • Dec 2021
                          • 66
                          • Poland
                          Hello, I would like to ask you to repair this BIOS file for HP
                          Model Hp pavilion 15-cs2008nw
                          pcb: DAG7BDMB8F0 REV F
                          SN: 5CD918124X
                          Thank you in advance. backup bios in the attachment​
                            • 22279
                            SN: 5CD918124X
                            Use the Guides to find and extract a virgin bios
                            [Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
                            [Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
                            Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
                            Offsets: 420000 - 42403F
                            HxD Hex editor https://mh-nexus.de/en/hxd/
                            • Ziome3eknh
                              • Dec 2021
                              • 66
                              • Poland
                              ami unfortunately does not want to open the files, it shows the message "The program has no any UAF image"
                                • 22279
                                Did you try running the exe and choosing copy to location https://www.badcaps.net/forum/troubl...53#post1827653
                                • Ziome3eknh
                                  • Dec 2021
                                  • 66
                                  • Poland
                                  yes is the same message
                                    • 22279
                                    hmm, it worked ok for me. Here`s your new bios
                                    • Ziome3eknh
                                      • Dec 2021
                                      • 66
                                      • Poland
                                      Thank you. Maybe it doesn't want to run on Windows 11? I program various bios on this computer and it works ok. This program doesn't want to read anything, I don't know why.
                                      • ky nguyen
                                        • Jan 2022
                                        • viet nam
                                        Hp pavilion 15-CS2034TU no display help
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
