NEC LZ750 .please help! recompose the original BIOS ME region
  • jason0503
    • Dec 2018
    • 27
    My NEC LZ750 started up with a black screen, and occasionally entered the system normally. After writing bios files dumped by others, it started up normally, but lost the activation information. Is there any kind person who can help me recompose the original BIOS information? Maybe need to synthesize the original ME into BIOS file dumped by others.please!
  • hoaca388
    Badcaps
    • Jan 2022
    • 12346
    Re: NEC LZ750 .please help! recompose the original BIOS ME region
    Try
    • jason0503
      • Dec 2018
      • 27
      thank you very much !!! i will try it later
      • jason0503
        • Dec 2018
        • 27
        it work !!thanks!!
        • Aimal
          • Jul 2024
          • Afghanistan
          How it work?
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Lexsmash85
            Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
            by Lexsmash85
            Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
            Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
            USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
            08-06-2025, 03:41 AM
          • Kentsfield
            Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
            by Kentsfield
            I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
            Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
            I desoldered the flash IC MX25U12872F and dumped the flash.
            I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
            08-04-2025, 07:46 AM
            by Vesko356
            08-11-2023, 03:27 AM
          • Wutru
            HP Elitebook 820 G4 BIOS repair assistance required
            by Wutru
            Hi guys,
            If someone would be able to provide some expertise, I'd be very grateful.
            BIOS Corruption - Cause
            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
            09-06-2025, 10:32 AM
