A2289 (820-01987) BIN file
  • hazem3636
    • Jun 2022
    • 35
    • sa
    hi there ,
    please i want someone support to find the BIN file for
    Macbook pro 13 inch " A2289 (820-01987) "
    all the best
  • hazem3636
    • Jun 2022
    • 35
    • sa
    Re: A2289 (820-01987) BIN file
    need T2 EEPROM dump
    • ajbernasko
      • Mar 2022
      • 229
      • ghana
      Hi please share if you have, thank you
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Flasman90
        Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
        by Flasman90
        Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
        My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
        What I have done so far:
        - All of the routine diagnostic methods including...
        08-29-2025, 08:38 AM
      • baglaivlad
        MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
        by baglaivlad
        Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
        Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
        01-09-2024, 09:55 PM
      • kenzo2
        Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
        by kenzo2
        I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
        I need dump file MACBOOK PRO A2159
        TSB4232(256)
        TSB4229(256)
        Thanks​
        01-11-2025, 04:18 AM
      • Woodsworth
        MacBook Pro A2289 no signs of life except clicking trackpad and charging
        by Woodsworth
        I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
        "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
        It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
        03-15-2024, 04:06 AM
