HP X360 1030 g8 Bios unlock
  • Holaa321
    • Jun 2023
    • 10
    • United Kingdom
    #41
    Re: HP X360 1030 g8 Bios unlock
    Would it be possible to also flash the bios chip as I've desoldered both of them off the motherboard or Should I just flash the EC and put the Bios chip back without any modifications?
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #42
      Originally posted by aldopc
      Ok write just the uec3 test and comment the result.
      Absolute is enabled too besides the Admin password in Holaa321's case, so modification of the EC dump is not enough, main dump must be edited too. The second option is to edit the main dump only but in MPM mode.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        In case of Admin password enabled only scenario, modifying the EC dump is enough and main dump can be leaved as is, but in your case that wouldn't be enough.
        • Holaa321
          • Jun 2023
          • 10
          • United Kingdom
          #44
          What would be the next ideal step to take? How is MPM Mode can be applied?
          Is the main Bios Chip data something that needs to be Modified? or Is there a different chip to be taken off the motherboard and read?
          • hoaca388
            Badcaps
            • Jan 2022
            • 12179
            #45
            Post EC and Bios Here.
            ​https://www.badcaps.net/donate
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #46
              Well it depends on the final result you want to achieve, if you want only the Admin password to be removed, but the enabled Absolute persistence module doesn't bother you flash only the edited EC dump.
              As I said by editing/patching the main dump. But afterwards you'll have to write back all the DMI information manually. You can collect all necessary info by taking screenshot of the system info page (F1 at boot), or it can be seen in your dump itself.
              Edit: Below is your main dump edited to boot in MPM mode:
              • Holaa321
                • Jun 2023
                • 10
                • United Kingdom
                #47
                Thank you for your explanation.
                I'll write the cleared bios on the bios chip. Then manually add the missing data on the computer afterward.
                I really appreciate your time.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #48
                  You're welcome.
                  Find attached to the post the image with the DMI information you'll need and separately the Feature byte as a code for copying.
                  Code:
                  476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAdpdqfPguhZjhk8mEmwn7nVngpDpqqx.Rq
                  • nabilgo
                    • May 2016
                    • 303
                    • L.A
                    #49
                    Re: HP X360 1030 g8 Bios locked need help
                    can anyone unlock this bios please hp elitebook x360 g8 bios password
                    Last edited by Vesko356; 07-10-2023, 12:51 PM. Reason: Attached bios removed. Thread hijack.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #50
                      Read the rules before posting, and do not hijack threads:
                      This thread is about "HP X360 1030 g8"
                      Your request ---> Serial Number : CND1130PGD, Product Number : 1H9W8AV, HP EliteBook x360 1040 G8
                      • DeadPicsel
                        • Mar 2023
                        • 3
                        • United Kingdom
                        #51
                        Hi.
                        Please could someone work their magic and remove the BIOS password from my HP that I have backed up the BIOS of.
                          • 21523
                          Originally posted by DeadPicsel
                          Hi.
                          You must provide the serial number - https://www.badcaps.net/forum/showthread.php?t=103570
                          • DeadPicsel
                            • Mar 2023
                            • 3
                            • United Kingdom
                            #53
                            Sorry, I did not realise.
                            Serial Number: CND24209RK
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12179
                              #54
                              Originally posted by deadpicsel
                              sorry, i did not realise.
                              Serial number: Cnd24209rk
                              aaa
                              • DeadPicsel
                                • Mar 2023
                                • 3
                                • United Kingdom
                                #55
                                Do I only need to flash the EC3 chip?
                                • auris
                                  • Mar 2017
                                  • 34
                                  • Lithuanian
                                  #56
                                  Hello plz help unlock bios
                                    • 21523
                                    Read the whole thread and the rules,then you should know what to do next.
                                    • macadam
                                      • Apr 2016
                                      • 51
                                      • United Kingdom
                                      #58
                                      hi
                                      i need a help
                                      hp elitebook x360 1030 g8
                                      bios need to unlock
                                      SN CND2061XMT
                                      509X4EC ABU
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #59
                                        Originally posted by macadam
                                        hi
                                        i need a help
                                        bios need to unlock
                                        Read posts #52 and #57
                                        • macadam
                                          • Apr 2016
                                          • 51
                                          • United Kingdom
                                          #60
                                          hi
                                          i provide the serial number
                                          sorry may be my English not good enough can you tell me please what else need to do
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                            HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 11:32 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:27 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 06:40 AM
                                            09-06-2024, 05:33 AM
