Hello members, is the file on the answer #20 (published by dilippawar31) working? has someone tested it so far?
hp pavillon dag3jbmb8d0 rev d bios
This bios works on my computer but it starts slowly, can someone help me clean ME.
Model 16-0014ns
S/N:5CD0256CF8
I have attached an original backup but it must be damaged because the client was turned off while updating the Bios. Of all the ones I have tried, only the one in this message has booted my computer.
Thank you so muchAttached FilesComment
HP Pavilion Gaming Laptop - 16-a0014ns
Model 16-0014ns
S/N:5CD0256CF8
Thank you so much↵
​https://www.badcaps.net/donateComment
Thank you very much, but it doesn't work either, I get that the Bios is corrupt, so I downloaded and repaired it with a USB, but I do the recovery with USB and it doesn't work either, the only Bios that starts well for me is the one I attached that was uploaded in this thread I don't know if you can clean that Bios and put the Serial data, model... from my Bios uploaded before.Attached FilesComment
Here
Thank you very much, but it doesn't work either, I get that the Bios is corrupt, so I downloaded and repaired it with a USB, but I do the recovery with USB and it doesn't work either, the only Bios that starts well for me is the one I attached that was uploaded in this thread I don't know if you can clean that Bios and put the Serial data, model... from my Bios uploaded before.Attached Files↵
Hello. Please help. Does not always display the image. If it doesn't start blinking caps lock 3 long 2 short. Thank You
DAG3JBMB8D0 REV D
HP 16-a0040nw​Attached FilesComment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
my laptop was working fine but aftter i update bios it won't work
anybody help me please
thanks
model Hp pavilion 16-a0076ms
mainboard code : DAG3JBMB8D0 REV ;D
serial ; 5CD0388khxComment
bios extracted from HP site update for HP Pavilion Gaming Laptop - 16-a0076ms
DMI 400000 - 4010FF
KEYWIN A7E000 - A7E03F​Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
model 16-a0003nu sn 5cd038lyvx mb dag3jbmb8d0 rev d it5570e-256 dont have backuo old ec is not workingComment
Try EC extracted from BIOS update, cut to 256KB
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
