X280 BIOS Password, tried short, now dead
  • zeezoo
    • Jun 2022
    • 3
    • dxb
    I've got Lenovo X280 with lost password issue. I've tried to short pins 5,6 multiple times as instructed and laptop was not taking it - it was going off or restarting, then it stopped working completely. Now it only lights up and then reboots but nothing comes up on the screen. It gets really hot as well and fans start spinning fast.
    Thinking bios chip died I got myself CH341A Programmer and new BIOS chips. Laptop uses this model 25Q128JVSQ.
    I did manage to backup up old BIOS and tried flashing other ones I found online but it just made things worse. After connecting charger light blinks few times and laptop generally stops responding to power button. More dead than before.
    I flashed old bios backup to new chip but it's same reaction.
    Then I tried to flash old bios backup to old chip and it got back to previous state - turning on and nothing on the screen, then restart and getting hot with fans spinning.
    I wanted to flash latest BIOS from Lenovo website but it only weights 9,455,008 bytes while original backup is 16,777,216 bytes long. There are actually 2 $0AN2000.FL1 files in 2 folders. One is N20ET61P and then N20ET61W. I did try UEFITool to extract bios but nothing is actually 16,777,216 bytes long. Maybe they have to be combined somehow?
    Does anyone have any solution for that?
    Regards,
    zeezoo
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    Re: X280 BIOS Password, tried short, now dead
    The solution is to upload here the original bios backup file.
    • zeezoo
      • Jun 2022
      • 3
      • dxb
      Uploaded
      • hoaca388
        Badcaps
        • Jan 2022
        • 12403
        Check your device again, there may be a short on the main board. Use the original file again, if the device works again, use the unlock tool in the link below.
        https://www.badcaps.net/forum/showth...novo+autopatch
        • winbond
          • Jul 2020
          • 56
          • uganda
          Hello, kindly unlock my back up for Lenovo x280 , board number NM-B521
            • 22087
            Please read the rules before posting,you must post the laptop serial number.Also read post #4 you can try to unlock it yourself.
            • cyngo
              • Jun 2015
              • 219
              • Indonesia
              This method is very risky and will not work, because the password is not in the bios IC. are pins 5 and 6 short?
              • Loli Popu
                DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                by Loli Popu
                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                12-13-2024, 03:28 AM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • tranquility
                Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
                by tranquility
                hallo,
                i have an asus X515KA-EJ058W here.
                just both leds white...he battery blinking without battery connected
                consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
                if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
                power on again is possible but again 400mA then and no picture.
                now the really strange
                i flashed bios (some version i found on the internet) and resoldered....sometimes...
                12-11-2024, 06:47 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
