Inspiron 7506 2-in-1 HELLCAT 19859-1 bios
Become a Badcaps supporter
Thanks to all supporters.
Hi all., I am working on a Dell Inspiron 7506 2 in 1. This BIOS is corrupted. It just boots up in the Screen Diagnostics Color mode & gets stuck out there. I used the Bin files in post #14, all worked fine but the Service Tag is a issue right now & every bootup I have to press Alt-F to go out of servcie mode. It boots up into BitLocker as the Tag # is not correct. I have attached the Original BIOS Bin file (64 & 128), kindly fix for me please. Service Tag # 1SC2CL3 .. Thanks in advanceLast edited by mferna14; 12-02-2023, 05:38 PM.Comment
----------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Buddy @hoaca388, thank you so much for the BIOS clean up. All works fine. 2 tiny problems, 1st one is that I cannot save the "Service Tag" in the BIOS, When I exit, the Service Tag column is blank again, I type again & upon exit , it does not save & 2nd is I cannot get laptop out of "Manufacturing Mode Active" by pressing "Alt-F". If possible ENTER/Type in the Service Tag (1SC2CL3) in the BIOS? Can you please help me, thanks in advance.Comment
There was at least one case that was resolved by replacing the CMOS battery, his CMOS battery was drained.
Add Service Tag ManuallyComment
My Dears., Did it at last. I have no idea why @hoaca388 & @qayyum786 did not work. The outcome of these Bin Files was whenever I wanted to save the Service Tag # in the black space, never saved. I replaced with a brand new CMOS battery & checked the volts before installing it (3.2V). But did not work. So what I did, I programmed the 128MB with my Original Bin files (AS IS) & only programmed @hoaca388 64MB to another chip. & all went fine. The service tag was intact & I was not getting any "Manufacturing Mode Active" error. Thanks you guys for your great help, really appreciate!!!Comment
my bios corrupt and i try few bios form here
after bios mainboard initialize and caps lock work but screen blank
please help to resolve this issueComment
my laptop DELL INSPIRON 7506 2IN1 bios corrupt. i need to repair.Attached FilesComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
please help with corrupted bios
see attached
HELLCAT 15 MS TGL 8L
19859-1
HGH1Y$LA
ST 61VST93
EC code: 13174572567
thank youAttached FilesComment
Service Tag: 61VST93
Please help, it turns on and it doesn't launch an image, I already tried with another bios and it works but the fans start up.
6050A2488301-MB-A02
ST:6LZGR93Attached FilesComment
please help me fix my Bios, the laptop works with it, but sometimes it doesn’t turn on, I need to disconnect and connect the battery and then the Bios is reset and the laptop works fine, I think that my Bios file is dirty. my service tag GDMPRG3
HELLCAT 15 MS TGL 8L 19859-1 BIOS.rar
Motherboard:HELLCAT 15 MS TGL 8L 19859-1
[QUOTE=omenwolf;n3272463]please help me fix my Bios, the laptop works with it, but sometimes it doesnAttached FilesComment
Okay, with a new BIOS it may be that a Dell logo only appears after the fourth boot attempt.
A good sign is that the keyboard backlight appears.
Maybe you just need a little more patience.
I can handle it most of the time.Comment
