Inspiron 7506 2-in-1 HELLCAT 19859-1 bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11810
    Re: Inspiron 7506 2-in-1 HELLCAT 19859-1 bios
    Originally posted by uagreen
    st: 3NQVF63
    Unlocked
    • uagreen
      • Sep 2021
      • 6
      • ua
      Thanks. Its work
      • mferna14
        • Jun 2018
        • 1026
        Hi all., I am working on a Dell Inspiron 7506 2 in 1. This BIOS is corrupted. It just boots up in the Screen Diagnostics Color mode & gets stuck out there. I used the Bin files in post #14, all worked fine but the Service Tag is a issue right now & every bootup I have to press Alt-F to go out of servcie mode. It boots up into BitLocker as the Tag # is not correct. I have attached the Original BIOS Bin file (64 & 128), kindly fix for me please. Service Tag # 1SC2CL3 .. Thanks in advance
        • hoaca388
          Badcaps
          • Jan 2022
          • 11810
          From #14
          • mferna14
            • Jun 2018
            • 1026
            Buddy @hoaca388​, thank you so much for the BIOS clean up. All works fine. 2 tiny problems, 1st one is that I cannot save the "Service Tag" in the BIOS, When I exit, the Service Tag column is blank again, I type again & upon exit , it does not save & 2nd is I cannot get laptop out of "Manufacturing Mode Active" by pressing "Alt-F". If possible ENTER/Type in the Service Tag (1SC2CL3) in the BIOS? Can you please help me, thanks in advance.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11810
              #26
              Buddy @hoaca388, thank you so much for the BIOS clean up. All works fine. 2 tiny problems, 1st one is that I cannot save the "Service Tag" in the BIOS, When I exit, the Service Tag column is blank again, I type again & upon exit , it does not save & 2nd is I cannot get laptop out of "Manufacturing Mode Active" by pressing "Alt-F". If possible ENTER/Type in the Service Tag (1SC2CL3) in the BIOS? Can you please help me, thanks in advance.
              Try replace cmos battery
              • mferna14
                • Jun 2018
                • 1026
                Thanks for the reply. I will do this 1st thing in the morning & inform you. Do you think it is because of this CMOS battery the Service Tag is not saving in the BIOS Setup???
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11810
                  #28
                  There was at least one case that was resolved by replacing the CMOS battery, his CMOS battery was drained.
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    #29
                    Try A New One
                    Add Service Tag Manually
                    • farhangcn
                      farhangcn commented
                      Editing a comment
                      i try this bios but screen blank any idea what is reason.
                  • mferna14
                    • Jun 2018
                    • 1026
                    My Dears., Did it at last. I have no idea why @hoaca388 & @qayyum786 did not work. The outcome of these Bin Files was whenever I wanted to save the Service Tag # in the black space, never saved. I replaced with a brand new CMOS battery & checked the volts before installing it (3.2V). But did not work. So what I did, I programmed the 128MB with my Original Bin files (AS IS) & only programmed @hoaca388​ 64MB to another chip. & all went fine. The service tag was intact & I was not getting any "Manufacturing Mode Active" error. Thanks you guys for your great help, really appreciate!!!
                    • farhangcn
                      • Aug 2022
                      • 5
                      • pakistan
                      #31
                      my bios corrupt and i try few bios form here
                      after bios mainboard initialize and caps lock work but screen blank
                      please help to resolve this issue
                    • farhangcn
                      • Aug 2022
                      • 5
                      • pakistan
                      #32
                      my laptop DELL INSPIRON 7506 2IN1 bios corrupt. i need to repair.
                    • nivirus2000
                      • Apr 2017
                      • 45
                      please help with corrupted bios
                      see attached
                      HELLCAT 15 MS TGL 8L
                      19859-1
                      HGH1Y$LA
                      ST 61VST93
                      EC code: 13174572567​
                      thank you
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11810
                        #34
                        see attached
                        19859-1
                        HGH1Y$LA
                        ST 61VST93
                        thank you
                        Service Tag: 61VST93
                        • nivirus2000
                          • Apr 2017
                          • 45
                          thank you, it worked!
                          • giacomo1428
                            • Feb 2020
                            • Perú
                            #36
                            Please help, it turns on and it doesn't launch an image, I already tried with another bios and it works but the fans start up.
                            6050A2488301-MB-A02
                            ST:6LZGR93​
                            • omenwolf
                              • Jul 2018
                              • 62
                              • Odessa
                              #37
                              please help me fix my Bios, the laptop works with it, but sometimes it doesn’t turn on, I need to disconnect and connect the battery and then the Bios is reset and the laptop works fine, I think that my Bios file is dirty. my service tag GDMPRG3
                              Motherboard:HELLCAT 15 MS TGL 8L 19859-1
                              • Markus1741
                                • Sep 2020
                                • 846
                                • N/A
                                #38
                                [QUOTE=omenwolf;n3272463]please help me fix my Bios, the laptop works with it, but sometimes it doesn
                                • omenwolf
                                  • Jul 2018
                                  • 62
                                  • Odessa
                                  #39
                                  [QUOTE=Markus1741;n3272473]
                                  unfortunately this does not work, it tries to turn on, the key backlight lights up, but the screen does not light up and so on in a circle
                                  • Markus1741
                                    • Sep 2020
                                    • 846
                                    • N/A
                                    #40
                                    Okay, with a new BIOS it may be that a Dell logo only appears after the fourth boot attempt.
                                    A good sign is that the keyboard backlight appears.
                                    Maybe you just need a little more patience.
                                    I can handle it most of the time.
                                      DELL Inspiron 7506 2in1 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 7506 2in1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7506 2in1 boardview and 7506 2in1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-07-2024, 02:50 AM
                                      09-06-2024, 09:30 PM
