hi all, the motherboard does not turn on, it had a short to a mosfet that powered the cpu, replaced the mosfet the pc turns on with a black screen, the cpu resistance is about 1.8ohm, it heats a lot, I wanted to make sure a bios working before a diagnosis with damaged cpu I am attaching the bios
hp 17-n106nl LA-c991P bios dump request
by AhariHi all,
I...-
Hello engineers š,
Iām kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as itās bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.š
š§ Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
š Problem:š
- Device shows āAdministrator Passwordā...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by greeliddHi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didnāt work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i canāt find a clean BIOS thatās a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...-
by olfelysRequest: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
My board enters jumper recovery mode but no BIOS files are available from HP anymore.
I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...-
- Loading...
