Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    • 21692
    Re: Lenovo IdeaPad L340-17IRH - need BIOS and EC dump
    Originally posted by Miim113
    Sorry man!
    There`s nothing wrong with that bios. If you want to try a newer version try the one at post #27 .If that doesn`t work you could try flashing the EC. Hardware issue or EC ? ,don`t know.
    • Miim113
      • May 2023
      • 10
      • Romania
      #42
      In EC file I don't need to change nothing?
      • Miim113
        • May 2023
        • 10
        • Romania
        #43
        Can you give me dump for "GD AH2033 25LQ80CTIG UAK261"?
        • carloska
          • May 2023
          • Romania
          #44
          Hi!
          Can somebody help me reading content of SPI ROM chip for my laptop?
          The technician told me, that the bios is good, but in meantime we lost the original content of Super IO chip witch is in the other side of motherBoard.
          He told me, that it would help, if I could get the same version of my laptop from somebody and read the content of that chip, but I found no one in my region.
          The laptop powers on, but does not boot, power button blinks.
          Lenovo IdeaPad L340-17IRH Gaming
          Model Name: 81LL
          SN: PF1TB56 MTM: 81LL00CYGE
          Mfg Date 2020/10/17 Factory ID. JVHFC1
          MO: PE9XB0A17136
          MotherBoard: NM-C361 rev 1.0
          Thanks!
          • peste
            • Dec 2016
            • 13442
            • ROMANIA
            #45
            Originally posted by carloska
            Hi!
            Model Name: 81LL
            MO: PE9XB0A17136
            Thanks!
            you have everything you need at post #6...
            • jendkkd jeje
              Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
              by jendkkd jeje
              So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
              I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
              10-11-2024, 03:12 PM
            • joven016
              Lenovo Ideapad S145 need working bios HELP!!
              by joven016
              Problem is blinking power led only
              i don't know exactly if it's s145-15igm or s145-14igm
              have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
              Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
              Already tested some of posted bios here
              S145-14igm - success but invalid serial and not booting on OS
              S145-15igm - success with serial and some other info in bios but still not booting on OS
              already tried installing new windows but always booting on bios setup
              windows installer flash drive detected on...
              08-21-2025, 10:55 PM
            • AHmad_Salal
              Need BIOS Dump/ROM for Lenovo Thinkstation p500
              by AHmad_Salal
              Hello all,
              I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
              11-28-2023, 05:28 AM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mximiliandz
              help bios lenovo ideapad s145-14iil type 81w6
              by mximiliandz
              Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
              06-20-2025, 06:50 AM
