Help nm-d281 rev1.0 LEGION 5-15ARH05H bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12269
    #81
    Originally posted by dev0009
    You right.
    Can you tell me where can i find BIOS chip on my laptop?
    Lenovo Legion 5 15ARH05H
    S/N: PF24CH05
    MTM: 82B1007VPB
    MB: NM-D281 Rev: 1.0
    I can upload a photo of my mb if needed.
    Legion 5-15ARH05H Laptop (Lenovo) - Type 82B1
    • dev0009
      • Jul 2025
      • 8
      • Poland
      #82
      Thanks. I flashed BIOS but no result.
      Maybe it's not a BIOS...?
      • GRHERHFDSCRHR
        • Jul 2025
        • 8
        • Ukraina
        #83
        Good day, I am looking for a BIOS for the Legion 5-15ARH05H Laptop (Lenovo) - Type 82B1 with Ryzen 7 4800h RTX 2060 motherboard nm-d281 rev:1.0 serial number PF1AVEGV.
        • peste
          • Dec 2016
          • 13430
          • ROMANIA
          #84
          post the contents of the bios chip even if it is corrupted..
          • GRHERHFDSCRHR
            • Jul 2025
            • 8
            • Ukraina
            #85
            This is all that was managed to be retrieved from the damaged BIOS.
              • 21679
              What programmer are you using to make the backup with. In the picture is what you posted on the right, and on the left is what it should look like after i converted it. Your backup should be in hex
              Click image for larger version  Name:	Whats this.jpg Views:	0 Size:	228.8 KB ID:	3708239
              • GRHERHFDSCRHR
                • Jul 2025
                • 8
                • Ukraina
                #87
                I am using the CH341A Programmer and I will give everything I managed to save, and now I don't know what to do.
                • GRHERHFDSCRHR
                  • Jul 2025
                  • 8
                  • Ukraina
                  #88
                  And what can no longer be done?
                    • 21679
                    What CH341A software are you using, have you tried NeoProgrammer and/or ASProgrammer .Try to make another backup
                    • GRHERHFDSCRHR
                      • Jul 2025
                      • 8
                      • Ukraina
                      #90
                      I am using AsProgrammer_1.4.1. And there is nothing left to do, unfortunately.
                        • 21679
                        Make another backup this time with NeoProgrammer, post it here, if it`s the same then will look at other options.
                        • GRHERHFDSCRHR
                          • Jul 2025
                          • 8
                          • Ukraina
                          #92
                          I can no longer make a backup, sorry.
                            • 21679
                            Try this bios - https://www.badcaps.net/forum/troubl...34#post3677934
                            If it`s working ok then you can change DMI with the lenovo U1 tool - https://www.badcaps.net/forum/troubl...24#post1622424
                            • GRHERHFDSCRHR
                              • Jul 2025
                              • 8
                              • Ukraina
                              #94
                              I flashed the BIOS with the programmer you suggested, and the laptop, as always, reacts to the start button; the LED lights up, then the laptop responds to FN+ESC, the LED stays on when pressed, then the chips play around, and after a minute, the fans start running at full speed and the laptop shuts down. If I remove the RAM, the laptop doesn't start in both slots, but it starts when the RAM is in one of the two slots.
                                SMDFlea commented
                                Editing a comment
                                If you put some pressure on the cpu it will probably start, if so the cpu needs reballing.
                            • GRHERHFDSCRHR
                              • Jul 2025
                              • 8
                              • Ukraina
                              #95
                              It seems that the processor is dead. Thank you for your help.
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • grimacelord
                                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                by grimacelord
                                Hello there.
                                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                History:
                                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                I searched for this error online and discovered...
                                03-15-2023, 03:29 PM
                              • faousi
                                BIOS Legion C730
                                by faousi
                                Hello frends,
                                I have an issue with this Computer. It doesnt boot, only fans are spining. I think I have a corrupted BIOS!
                                So I have read an save BIOS from the chip with a ch341A programer.
                                On the Lenovo driver site I have downlaoded the BIOS-Update but I cant extract the BIOS-Firmare to program the chip!
                                Can someone help me!
                                I have a
                                Legion C730-19ICO Desktop (Lenovo) - Type 90JH
                                Serielno. : S1011C9G​
                                That is the Link to the lenovo BIOS:
                                https://pcsupport.lenovo.com/de/de/p.../legion-c730-1...
                                01-13-2025, 09:46 AM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
