820-00923 clean me region
  • Sengly
    • May 2022
    • Cambodia
    Help me please!
    i have problem with Logic board 820-00923. it's not work normaly, in case on battery power source ( not yet connect type C power source ) disconnected force_touch trackpad and when battery level under 3% when we press turn on button about 9 second or more later it will appear low battery icon on display then try to plug in Type C power source immidately it's will appear apple logo and sound chime then sometime stucked sometime run to mac OS sucess. if we tun it on on battery power by battery level over 3% or with type C adaptor power sourse the logic board will not work and it's not appear any things on screen.what i had tried to do on the logic board, replace U7000, U7100,U5000 (SMC) reballing CPU and try to reprogram EFI Bios chip from Internet with try to clean me_region with some techniqe from Internet but i can't clean me_region currectly. i don't know the currect way to clean it.
    any friends here any ideas about this logic board problem? I have tried to find missstake on this logic board in weeks but still don't know the mistake. in Attachments folder have 00923.bin file please help me to clean me region. thank you
  • hoaca388
    Badcaps
    • Jan 2022
    • 12322
    Re: 820-00923 clean me region
    Originally posted by Sengly
    Help me please!
    Here
    • Sengly
      • May 2022
      • Cambodia
      thank you hoaca388. With your original EFI for 00923 clean ME it's better than ever. The logic board can run normally to Mac OS on the adapter power source only, but when I connect the battery it will get stuck on the Apple logo. after it work with your EFI I try to rewrite with Original EFI, it also work the same yours too. the wifi hardware on this logic board not working. I think all problem on this logic boaed relatived to wifi error.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
      • korben_dallas
        Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
        by korben_dallas
        Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
        I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
        I'm new to soldering but the only feasible way to fix this issue is to do something myself.
        MY QUESTION:
        I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
        02-14-2024, 12:23 AM
