HP 840 G7 DMI info
  • adom
    • Sep 2021
    • 12
    • Switzerland
    HP 840 G7 DMI info
    Hi, everyone
    what is the easiest way to change the serial number of the 840 g7?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: Change Serialnumber, HP 840 G7
    Copy dmi block from original bios , paste into new bios by HxD editor.
    • adom
      • Sep 2021
      • 12
      • Switzerland
      how can i reset the dmi?
      • aamkaachaar
        • Jun 2013
        • 7
        • india
        need to locate DMI info inside my dump , any help would be appreciated
        • aldopc
          • Jul 2017
          • 484
          • Chilito
          Hi Bro this is your dmi info
          Product Name : HP EliteBook 840 G7 Notebook PC
          Serial Number : 5CG0395TTD
          Product Configuration ID : 24M80UP#ABA
          BuildID : 20WWCMAT601#SABA#DABA
          FeatureByte : 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mE.ye
          System Board CT Number : PJSCQ00WBE90YP
          • aamkaachaar
            • Jun 2013
            • 7
            • india
            brother i need dmi location address in HEX editor
            • hpboy
              • Jan 2021
              • 53
              Open you BIOS dump file in HxD
              Run a Search (Menu -> Search, Find) for your current Serial (using Unicode Text Encoding)
              Replace your Serial number with the new number
              Save the BIOS dump as a new file name
              Done
              Ps - do not forget to run the same process on the back up recovery BIOS (if your laptop has one), otherwise your edit will be overwritten by the back up.
              • Veyron7887
                Laptop overheating after replacement thermal paste
                by Veyron7887
                Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                11-24-2024, 05:08 AM
              • bruce35
                HP 600 G3 MT serial number change please
                by bruce35
                HP 600 G3 MT
                SERIAL NUMBER MXL8301K1C Serial number in the file in bios
                SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
                Thank you very much...
                09-24-2025, 02:32 AM
              • GardevoirForEver
                Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                by GardevoirForEver
                I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                The motherboard of my ASUS...
                11-15-2025, 04:30 PM
              • relax79
                x7400pc r4.0 bios
                by relax79
                Hello friends, sorry for my poor English.this notebook power led always on when i plug in dc adapter and there is no charge led or charge activity. Main vcc show 8.4v and what i see this design uses low supply rail equal to battery like macbooks. I try to download from support and it says latest one 303 but when i unpack with Uniextract then i learn it is crypted then i find ami guard tool then i read in hex editor it says 309 somehow but no problem because mine also same, i copy paste new bios via hex editor and programmed via programmer but nothing cahange. Rest is i do not know how to repair...
                02-01-2025, 09:05 AM
              • Dannyx
                UART (serial ?) splitter ?
                by Dannyx
                Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
                The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
                The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
                08-18-2023, 03:21 PM
