HP ELITEBOOK X360 1040 G7 - "power-on authentication" problems.
  • dfear
    • Mar 2013
    • 55
    A customer dropped off a HP ELITEBOOK X360 1040 G7 with a "power-on authentication" problem.
    Customer says he didn't set this up. Neither password or fingerprint works.
    I have tried flashing:
    1) JBIOS1UH2
    with:
    a) RCUnlocker (by RethoricalCheese). Didn't do anything, beacause the chip is 32MB in size.
    b) HPUnlocker (by mazzif). Made a small change (changed: "00 00 00 00" to "FF FF FF FF".
    result: "power-on authentication" is still present.
    2) UEC3
    with:
    a) RCUnlocker (by RethoricalCheese). Makes a big change (see the attached screenshot).
    b) HPUnlocker (by mazzif). Made a small change. The change is similar to the change made to JBIOS1UH2. It changed 71x "FF"s to "00". Don't think I wrote thhis one back to the chip.
    There is another Winbond chip next to UEC3 designated UT9. The chip is a Winbond 25Q80DVIG. The 25Q80DVIG is a "3V 8M-BIT SERIAL FLASH MEMORY" chip. That means the chip is 1MB in size. Does anyone know what this chip is for? Is it worth it to dump it and run it through RCUnlocker/HPUnlocker?
    Does anyone have any other suggestions on how to remove "power-on authentication"?
    Thanks David
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: HP ELITEBOOK X360 1040 G7 - "power-on authentication" problems.
    Upload both bios dumps here.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • dfear
      • Mar 2013
      • 55
      I have included before and after dumps (using RC Unlocker and HP Unlocker).
      • mrwab
        Banned
        • Jan 2014
        • 83
        • morocco
        Maybe you didn't make a good bios backup
        • mrwab
          Banned
          • Jan 2014
          • 83
          • morocco
          please backup again
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Both two files must be written to the corresponding chips simultaneously.
            • bojc
              • Jan 2021
              • 17
              • Slovenia
              Hello
              can anyone also unlock mine?
              Thank you
              BR
              Bojan
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Originally posted by bojc
                Hello
                Thank you
                BR
                Bojan
                Please consider donation in support of the "Bios Requests" section of the forum.
                I've attached your unlocked dump:
                • bojc
                  • Jan 2021
                  • 17
                  • Slovenia
                  it works
                  thank you very much
                  • bojc
                    • Jan 2021
                    • 17
                    • Slovenia
                    could you also unlock this one
                    thank you
                    BR
                    Bojan
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      thank you
                      BR
                      Bojan
                      There's no complications in your case now, only Admin password, no additional password protected user(s) or Computrace, so you can use RCUnlocker with your 16MB dump only, leave the 32MB chip as is. At first boot reset bios settings to factory default save/apply, then reset security settings and you're good to go.
                      • bojc
                        • Jan 2021
                        • 17
                        • Slovenia
                        thank you Sir
                        • Birch
                          • May 2024
                          • Slovenia
                          I would like to use this thread for some question about fixing the BIOS on a HP Elitebook x360 1040 G7 laptop.
                          At this moment I think that the only problem I have is similar to the one bojc had, my BIOS is admin locked.
                          There are 3 chips that I am eyeing at this moment:
                          25Q256JVEN (says BIOS next to it on the motherboard)
                          25Q80DVIG (says UT9 next to it on the motherboard)
                          25Q128JVPQ (says UEC3 next to it on the motherboard)
                          First thing I did is disconnect the battery from the motherboard and then I tried to read the data from these chips with CH341A and the additional clamp it came with.
                          I am quite sure that I've used the correct pins based on the datasheets, but I had no luck with reading these chips. From what I've been able to read on the web these clamps can be quite useless.
                          So now I've decided to try either soldering some wires to the chip pins or removing it from the board (i'd rather not since I do not have hot air station, only a portable soldering iron).
                          Could you please instruct me which chip is the correct one to flash with RCUnlocker to remove the admin password so I won't have to go through trial and error to find the one that has the 16MB program on it.
                          Thank you all so much and sorry for the amateurish question since I am quite new to this.
                          Have a good week!
                          • kossie
                            • Oct 2023
                            • 4
                            • netherlands
                            hello everyone.
                            could someone help me?
                            i have a hp elitebook x360 1040 G7 and have already read the bioschip but the HPunlock tool does not work with a 32bit version.
                            does anyone have a tip for me to still get this bios free of password?​ or could someone do it for me?
                            thanks in advance
                              • 22097
                              Originally posted by kossie
                              hello everyone.
                              thanks in advance
                              Please read https://www.badcaps.net/forum/troubl...before-posting ,and type the laptop serial number.
                              • kossie
                                • Oct 2023
                                • 4
                                • netherlands
                                i am sorry, SN CD04678VS
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12407
                                  HP EliteBook x360 1040 G7 Notebook PC
                                  CT Number_6JLJV07WYE10JE
                                  Serial_CND04678V5
                                  Sku_229K8EA#ABH
                                  Build Id_20WWHCAT601#SABH#DABH
                                  Fearture byte_3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbVbhcAdUdpdqfAfPguhKhZj4jhk8mE.de
                                  ​https://www.badcaps.net/donate
                                  • kossie
                                    • Oct 2023
                                    • 4
                                    • netherlands
                                    thank you so much
                                      HP EliteBook EliteBook x360 1040 G5 Notebook PC Notebook 1000 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook EliteBook x360 1040 G5 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1040 G5 Notebook PC boardview and EliteBook x360 1040 G5 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                      09-06-2024, 09:53 AM
                                      09-06-2024, 07:20 AM
                                      HP EliteBook x360 1040 G9 Hybrid (2-in-1) Specification for Upgrade or Repair
                                      This specification for the HP EliteBook x360 1040 G9 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G9 boardview and 1040 G9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                      09-07-2024, 05:20 AM
