ASUS TUF GAMING FX705DY - need BIOS dump
  • outsider
    • Apr 2014
    • 104
    • localhost
    Hello!
    I need BIOS dump file ASUS TUF GAMING FX705DY.
    I don't have old dump because someone clear flash chip
    Best regards!
  • peste
    • Dec 2016
    • 12822
    • ROMANIA
    Re: ASUS TUF GAMING FX705DY - need BIOS dump
    Originally posted by outsider
    Hello!
    Best regards!
    if you don't have the original bios, take clear pictures with the stickers from the ram memory area or a square with a QR code ... the model of the motherboard ..
    • outsider
      • Apr 2014
      • 104
      • localhost
      PCB: Pegatron FX505DY REV. 2.1
      CPU: AMD Ryzen 5 3500U (YM3500C4T4MFG)
      GPU: 215-0908018 (AMD Radeon RX 560X)
      KBC: ITE IT8225E-128 CXS
      BIOS: MXIC MX25U12873F (128 Mbit = 16 MB)
      • peste
        • Dec 2016
        • 12822
        • ROMANIA
        clear pictures with the motherboard on both sides ...
        • outsider
          • Apr 2014
          • 104
          • localhost
          I only have this photo.
          • peste
            • Dec 2016
            • 12822
            • ROMANIA
            on both sides of the motherboard
            • outsider
              • Apr 2014
              • 104
              • localhost
              What do you really need it for? I would have to disassemble the motherboard. Is the data I provided insufficient?
                • 20938
                See the barcode sticker on this motherboard at aliexpress https://www.aliexpress.com/item/1005002186883561.html ,the model FX705DY is on the sticker,that is the bios version that should be flashed to that board. Sometimes the model number on the sticker (or QR code) is different to the silkscreened number. https://www.badcaps.net/forum/showthread.php?t=96604
                • dhibubabu
                  • 50
                  • UAE
                  Which one having bios password ?
                  Ec or main bios ?
                  • dhibubabu
                    • 50
                    • UAE
                    Original with password
                    please remove password
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      Here's your Unlocked Bios, try it.
                      all donations are welcome,
                      • dhibubabu
                        • 50
                        • UAE
                        laptop not turning on with this bios
                        • hardware1
                          • Sep 2021
                          • 2930
                          • N/A
                          Try to program back the original Bios and see if the device will works or not.
                          • nonan
                            • Jul 2022
                            • 7
                            anyone got a good bios dump for FX705DY ?
                            Mine keeps freezing when booting the operating system. Tried windows and ubuntu both freeze with the Asus logo and loading icon. Sometimes on Windows boot it will give BSOD DRIVER PNP WATCHDOG
                            Bios does enter fine and windows installer can be started aswell but not booting into windows.
                            • hardware1
                              • Sep 2021
                              • 2930
                              • N/A
                              Upload your Original Bios, write your Device Full Model and Serial Number.
                              • Ferimonka
                                • Nov 2019
                                • 40
                                • United Kingdom
                                Hello. I am strugling to find a bios for my laptop w hich turns on with keyboard backlight and after 15 secs the fans start spining at the full speed. No picture. I can't find the motherboard number but it is FX705DY-EW004T, SN: K2NRCV00F340067
                                I tried bios from this post but computer doesn't start with these. Attached original which starts on with backlight and fans. Please help.
                                • danito
                                  • Jun 2016
                                  • 948
                                  • Romania
                                  try
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • DynaxSC
                                    by DynaxSC
                                    06-14-2024, 03:49 PM
                                  • smallvhin
                                    ASUS B150 PRO GAMING AURA help bios updating
                                    by smallvhin
                                    Master help to fix my bios stock in "bios is updating" I already update my bios to first release and latest but no luck.
                                    more thanks
                                    bios file
                                    ec file...
                                    07-14-2025, 10:51 AM
                                    ASUS TUF Gaming FX505GM-AL323-GAMING Notebook Specification for Upgrade or Repair
                                    This specification for the ASUS TUF Gaming FX505GM-AL323-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505GM-AL323-GAMING boardview and FX505GM-AL323-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-06-2024, 09:01 AM
                                    ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                                    This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
