Fujitsu E557 BIOS
  • reformatt
    • Feb 2020
    • 1533
    Fujitsu E557 BIOS
    Have another shop bring in a Fujitsu E557 where they chose to do Windows optional updates. One of these was a BIOS update to V1.16. After applying, it got into a reboot loop and he pulled the power. Now the power light comes on, then a few others, attempts to power on and switches off.
    Seems this maybe an issue with this update as it's already been reported by someone else on their forum. Fujitsu told them to replace the board (ha ha).
    Anyway, Fujitsu at least have the V1.18 BIOS update available and there's a BIOS ROM in it. File size is different to that extracted in FIT so I'm not 100% sure about just dumping that in with FIT. This motherboard has a Fujitsu embedded controller on it, so have no idea how to reprogram it if something goes awry in the BIOS code.
    So attached is a dump of this system and the ROM file in the V1.18 update. Is it ok just to put this ROM into the FIT and rebuild the image? I assume the extra space is for DMI/NVRAM variables.
    Motherboard part number is CP695750 but it also has a sticky label CP729434-01
  • hoaca388
    Badcaps
    • Jan 2022
    • 12392
    Re: Fujitsu E557 BIOS
    Lifebook e547
    • reformatt
      • Feb 2020
      • 1533
      Many thanks, only got back to this today. Tested and fully working. S/N is still correct as well.
      I note it's Insyde BIOS so have some reading up to do on how to fix these like you have.
      • Adam jokh
        • May 2017
        • MAROC
        POWWER ON BUT NO IMAGE FIX IT PLZ
        • hoaca388
          Badcaps
          • Jan 2022
          • 12392
          You MUST:
          • Read BIOS guides, methods, resources and tools
          • Try the method at BIOS guides, methods, resources and tools before requesting help
          • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
          • Use search function in case someone already answered your request
          • Post under a related thread if it exists
          • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
          • Name your thread with make, full model numbers and request
          • Provide a BIOS/EC dump if possible
          • Attach files directly to your post instead of linking to external websites
          • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • akwky
            by akwky
            Hi!
            04-14-2025, 01:56 PM
          • tofuSCHNITZEL
            Fujitsu Lifebook E547 vPro
            by tofuSCHNITZEL
            I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
            What I've tried:
            I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
            for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
            10-15-2025, 04:26 PM
          • al3m0di
            Update bios EFCN58WW to EFCN59WW
            by al3m0di
            Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
            I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
            The BIOS version is EFCN58WW.
            When I turn on the device, it displays the message:
            "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
            The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
            I've tried
            07-29-2024, 10:32 AM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
