need bios GDC31 LA-K371P rev.3.0
hi good day.
Dell Latitude 7420
GDC31 LA-K371P Rev. 3.0 (A02)
ST: 77QGKN3
Need help for this bios file. With this original bin it takes many attempts to switch it on before it will display and you can use the laptop normally. with post #32 i tried that, easily switched on but no display and will turned off after about 1 minute.
may i request for the repair of this bin?
thank you in advance..Attached FilesLeave a comment:
hi good day.
Dell Latitude 7420
ST: 77QGKN3
your laptop is latitude 7320, pay more attention when you write. Here's your unlocked bios, next time use this tool:
https://www.badcaps.net/forum/troubl...l-8fc8-patcherLeave a comment:
Dell latitude e7320 password, please help
ST: 54RX8D3
dell latitude 7420 no display la-k371p
light blink 3 orange 6 whiteAttached FilesLeave a comment:
3 dumps with clean me bios
UC2_GD25R256DYIG
U1 XMC QH128AHIG
UPD7 W25Q80DVSIGAttached FilesLeave a comment:
help me rebuild this bios..at first the prob is bios password 8fc8, after patching no power just small orange light..
ST:8dj6qn3Attached FilesLeave a comment:
i need help to fix my bios la k371P
MFGYR 2022
SERVICE TAG CVBN2M3
EX 28015391739
my old biosAttached FilesLeave a comment:
Guest repliedHello! My laptop won't turn on. Only LCD test available. Please help. I try to flash many dumps, but no luck. 8(
Dell latitude 7420
LA-K371P rev 3.0
ST: 57WDXD3
Original dump attached.
Thanks!Attached FilesLeave a comment:
ST 8TXKKN3
UNLOCK PLEASE AND DISABLE ABSOLUTE PLEASE THANK YOUAttached FilesLeave a comment:
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
