need bios ACER NITRO AN515-54
  • Bonecr7
    • Jun 2018
    • 3
    • Mexico
    #41
    La Acer encendia y se apagaba al limpiar ME solo enciende sin imagen se iluminan led del teclado solamente y ventiladores giran, revise Vbios y aparentemente todo ok solo que en el esquema me aparece que es de 8mb pero solo me pesa 1mb, igual dejo el backup tanto del bios de 16m y el Vbios de 1MB.
    Model: Acer Nitro AN515-54-78E0
    SNID: 04806046834
    S/N: NHQ5BAL0060480EC343400
    Use Traductor
    The Acer turned on and off when cleaning ME, it only turns on without an image, only the keyboard LED lights up and the fans rotate, I checked Vbios and apparently everything is ok, except that in the diagram it appears that it is 8MB but it only weighs 1MB, I still leave the backup both the 16m bios and the 1MB Vbios.​
    • peste
      peste commented
      Editing a comment
      merged post..
  • DolphiServiceLTD
    • Apr 2024
    • 25
    Hello!
    I need bios dump for this one :
    No display, just fan spining. Red light keyboard, charging fine.
    SNID: 91903285834
    AN-515-54-7064
    NHQ59EX0189190805A3400
    Thank you in advance!
    • hoaca388
      Badcaps
      • Jan 2022
      • 11298
      • Viet Nam
      #43
      Originally posted by DolphiServiceLTD
      Hello!
      SNID: 91903285834
      AN-515-54-7064
      Nitro AN515-54
      • test loja
        • Mar 2024
        • 6
        • brazil
        #44
        Hi, I need the bios (16mb + 1mb) for this Acer notebook, please.
        AN515-54-71CC
        S/N: NHQ6PAL00C023E82C89501
        Acer Nitro Intel i7
        • hardware1
          • Sep 2021
          • 2912
          • N/A
          #45
          AN515-54-71CC
          Acer Nitro Intel i7
          Upload your Original BIOS even if it's corrupted. I think this laptop has 2 chips, 16MB for BIOS and 1MB for vBIOS (graphic firmware).
          all donations are welcome,
          • test loja
            • Mar 2024
            • 6
            • brazil
            #46
            Ready friend.
            In this case, it has an orange LED when I insert the charger, when I press the power button, the blue LED lights up and a few seconds later the blue LED goes off but the orange LED stays on, but the note doesn't turn on.​
            • hardware1
              • Sep 2021
              • 2912
              • N/A
              #47
              Ready friend.
              Your 1MB file (vBIOS) is fine, It's identical to the file that I have, so just solder back this chip and don't make any changes on it.
              Your 16MB file (Main BIOS) is messy, you will have to read the chip again in a proper way. Are you using a clip/clamp or de-solder the chip? Which SPI Programmer do you use?
              • test loja
                • Mar 2024
                • 6
                • brazil
                #48
                I removed the chip from the motherboard and used a CH341A eprom burner and NeoProgrammer V2.2.0.7
                What do you recommend me to do?
                I'm doing this process because out of nowhere this notebook stopped turning on... I suspect the bios has been corrupted​
                • hardware1
                  • Sep 2021
                  • 2912
                  • N/A
                  #49
                  Try to read the chip again. Also send an image for your chip number and the adapter that you are using to connect it to the programmer.
                  • test loja
                    • Mar 2024
                    • 6
                    • brazil
                    #50
                    follow the photos friend
                    • hardware1
                      • Sep 2021
                      • 2912
                      • N/A
                      #51
                      Here is your new file, it's a virgin BIOS from Acer with your DMI.
                      • test loja
                        • Mar 2024
                        • 6
                        • brazil
                        #52
                        I re-recorded the bios and now the notebook turns on, the keyboard LED lights up, the fans spin and after about 10s it turns off (no image). And it stays in that cycle.
                        Before talking to you I had re-recorded the VGA's bios, would you have its bios to give me to test if this could be the case now?
                        Or could it be a defect in something else?​
                        • hardware1
                          • Sep 2021
                          • 2912
                          • N/A
                          #53
                          Ready friend.
                          The vBIOS that you uploaded here is fine, you can use it.
                          • madjid911
                            • Dec 2016
                            • 364
                            • France
                            #54
                            Hello, I have the same laptop without display, I have all the voltages, 1V2 and 2V5 RAM, 3V4 and 1V8 bios, it charges the battery well, turns on and off correctly, but does not display anything internally or in external. I tried several rams on it.
                            Originally, it didn't turn on at all, the laptop had a PQM1 short mofset that I replaced, now the ram is well powered and it turns on very well.
                            I tried several bios here without result, I compared the 1mb bios with yours it is indeed identical.
                            What is the next step please? maybe the graphics card is dead? Can we have a main bios without the graphics card option?
                            Acer NITRO AN515-54
                            sn : NHQ59EF0170350CFBD3400
                            Motherboard : EH5VF LA-H501P
                            • Golovaj
                              • Jun 2024
                              • kazakstan
                              #55
                              thank you very much.very helpful.It's a very good website.
                              • Mivecool
                                • Dec 2024
                                • 3
                                • Канада
                                #56
                                Originally posted by peste
                                Re: need bios ACER NITRO AN515-54
                                bios extracted from the ACER site update
                                DMI 370000- 371FFF
                                Thank you very much you the best
