Alienware M15 orion mb n18e rev a00 bios file request
  • spike888ph
    • Jun 2015
    • 31
    • Philippines
    I am looking for a working bios file for the following brand and model
    Alienware M15
    SERVICE tag: 4P2RK42
    motherboard: orion_mb_n18e rev A00
    original bios dump:
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • kamkam336
    Alienware Aurora R8/9 Bios .bin file needed
    by kamkam336
    I got a new mobo from Aliexpress for my Aurora r9 and everything was working fine until i did a bios update. It did not work and now i get 3x, 7x, 3x, 6x blinking code. Dell says that is a corrupt bios. So i have the ch341 and software required, i just don't have the bios.bin file.
    Since the board is from Aliexpress it doesn't have a service tag, I have a copy of the .exe bios and a copy of my corrupted bios attached. Hopefully this is enough, if anyone is able to help me and requires any more information please let me know.
    Thanks ...
    08-19-2024, 06:59 PM
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
