Lenovo Thinkpad E495 help unlock
  • hello1321
    • Feb 2025
    • 4
    Thank you, does it work with secure boot enabled?
    • hello1321
      • Feb 2025
      • 4
      Originally posted by peste
      thank you very much. I have one question, if secure boot is enabled on the system, does it still work or is there no chance of resetting the password?
      • hello1321
        • Feb 2025
        • 4
        sorry, meant to only send it once. thought my first one disapperead because it wasn't shown to me
        • boron.819
          • Apr 2025
          • 3
          • POLAND
          #84
          Hello, I'm a new user here on badcaps and although I am not as experienced yet, I'm happy to learn much more about computers than I know now.
          So I recently bought a ThinkPad E495 from the used market and the laptop was working just fine. But I quickly noticed that the BIOS had a supervisor-password enabled.
          When I asked the seller, if he could tell me the password, he said that he unfortunately forgot.
          After trying to leave out any source of power to the computer, including the CMOS-battery for a few hours, as it was recommended to try first (which didnt work), I then decided to locate the BIOS-chip (winbond 25Q128FWSQ, of which I have a link to the datasheet attached) and carefully short the 5th and 6th pin with a screwdriver, a method I have seen several times before. I tried it three times, of which the first two tries didn't do anything and the laptop just continued to boot and load in to the OS unfazed. I suppose that the timing wasn't right, because I have read that this is very important when doing this method. The third time I tried it, the screen just went black and the laptop became completely unresponsive. Everytime I turn it on, the powerbutton lights up and the Caps-Lock-Light also stays on (even when you press down). The CPU heats up for a few minutes and the fan turns on, the CPU cools down and the fan goes off again. This just repeats itself over and over again. I have also tried removing the RAM, expecting the beeping sound that warns you because of the lacking RAM-Memory during boot, but this was also not happening. I went on to research a bit more about this issue and found the method of flashing the BIOS-chip with a CH341A-Programmer. I bought one, which had a 1.8V-adapter included, and began to read out the chip. I backed-up this existing data and erased the chip. I then found the necessary .bin files in this Forum. I also managed to extract the .bin file from the CD-ISO that Lenovo provides in their BIOS-Update section for my E495 on their website. I tried to write these .bin files on the chip many times, always checking the connection to the chip with the verification feature on ASProgrammer, but sadly the behavior of the laptop doesn't seem to change at all. I also checked the voltage on the 25Q128FWSQ with a multimeter (black on ground pin 4 and red on VCC pin 8) and it receives exactly 1.8V. I can't really imagine the chip or the regulator being fried although I can't say for sure.
          At this point, I am not quite sure how I should continue and what to do/try next.
          I am thankful for any advice in advance!
          • peste
            peste commented
            Editing a comment
            post merged....next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you
            can't find it, then make a new thread..
            post the bios here on the site, not on other sites..
        • peste
          • Dec 2016
          • 12812
          • ROMANIA
          #85
          post S/N, full name and model, motherboard model,,TYPE,etc.
          post the contents of the bios chip even if it is corrupted..
          read the forum rules..
          https://www.badcaps.net/forum/troubl...ore-posting​
          • boron.819
            • Apr 2025
            • 3
            • POLAND
            #86
            I apologise, here is more info:
            Lenovo ThinkPad E495 Ryzen 7 3700U
            Type 20NE-000BGE
            S/N: PF28E02D
            motherboard NM-c061
            Motherboard FRU should be 02DL980
            Attached is the first backup of my 25Q128FWSQ BIOS-chip
            • danito
              • Jun 2016
              • 939
              • Romania
              #87
              Type 20NE-000BGE
              S/N: PF28E02D
              motherboard NM-c061
              try
              • boron.819
                • Apr 2025
                • 3
                • POLAND
                #88
                Originally posted by danito
                try
                I actually managed to get it working again, thank you very much!
                • apostsamking
                  • Dec 2017
                  • 117
                  • Ghana
                  #89
                  Good day every one. Pls i have a lenovo E495 laptop but bios locked. i tried using Lenovo auto patcher put it didnt, i have black screen. can anyone help me unlock it. file below.
                  Type: 20NE-000JUK SN: PF-2AE048. THANKS.
                  • ibuprofeno
                    • Apr 2016
                    • 6
                    • colombia
                    #90
                    podrĂ­an ayudarme a autoparchear y posiblemente reemplazar la NVRAM en el archivo de volcado de BIOS original adjunto de mi Thinkpad E495.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1226
                      • France
                      #91
                      try
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1226
                        • France
                        #92
                        in english please
                        • ibuprofeno
                          • Apr 2016
                          • 6
                          • colombia
                          #93
                          Could you please help me self-patch and possibly replace the NVRAM in the attached original BIOS dump file from my Thinkpad E495.
                            • 20898
                            Type the laptop serial number, full name and model, motherboard model, etc.
                            read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                              Lenovo ThinkPad ThinkPad E495 Notebook E Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E495 boardview and ThinkPad E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 08:44 AM
                              Lenovo ThinkPad E495 Notebook E Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad E495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E495 boardview and E495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                              09-06-2024, 02:28 PM
                              09-06-2024, 12:36 PM
